bright_pearson
R-world Applications Not Opening
For the past three days certain applications are not opening on LgRD 6130. applications like games, and tools womens world, ringtones etc are not opening. Is there any software update for this? I have the version 15 software. anyone else facing the same problem??? :help:
  bright_pearson said:
For the past three days certain applications are not opening on LgRD 6130. applications like games, and tools womens world, ringtones etc are not opening. Is there any software update for this? I have the version 15 software. anyone else facing the same problem??? :)
33227[/snapback]
My phone is working fine with the above version 15 software. I am not facing any problem. maybe the local area where you are using your phone may be having some problem like network problem or something. This is just a assumption.
Hi Dear,
As u know that the java based applications comsume memory on the handset so when u have already used many applications there might be not enough memory to launch the other application,Still the message after the unscuccessfull launch of the application should give u an idea of what went wrong.
A R World not Connected error is possibly due to a network failure,maybe the data call was dropped due to congestion in the BTS (Transmission Tower) U fall under at that point in time. This problem will be solved if u do try again.
A R World not Ready error is most probably due to either a failure at the server side or due to memory/JVM complications at the mobile handset.
The Best solution to memory related problems is to do a clear mempory the application is located under : RWorld -> More Services --> Tools --> Clear Memory.
And still if the problem persist u may try to shut the JVM [ Java Virtual Machine] in the phone down and give it a reboot ie reboot ur phone.
Worse still if application is still not getting to run u should name the application on the forum may be some one will provide a better solution.
Do reply back to tell if this was of any use.
Thanks,
