nikhilraut
230.4 kbps Connection On LG 6130
Has anyone tried on prolific chip based data cable(for RD2030)? :wacko:
i tried..
(by adding this line in inf file)
HKR,,ConfigData,1,01,00,3F,3F,10,27,88,13,C4,09,E2,04,71,02,38,41,9c,80,4E,C0,34,00,0D,00,0D,00,06,40,03,80,00,00,d0,80
but it didn't work... :)
i know chip support buad(?) rate of more than 230 kbps but i don't know how set higher buad rate
if some tried in this chips...plz share.. :clap::grin:
I am having PL2303 USB/SER chipset based grey market cable and it works without
any problem at 230.4KBps speed between my RD2130 and PC node.
Ahhh but I am free of WDM and associated INF crap, I am riding on LINUX :P .
Has anyone tried on prolific chip based data cable(for RD2030)? :confuse:
i tried..
but it didn't work... :help:
if some tried in this chips...plz share.. :confuse::confuse:
Ahhh but I am free of WDM and associated INF crap, I am riding on LINUX :confuse: .
how u did that on linux?
can u post that screen shot?
and information on how to do that on linux based os?
thanx.
thanx.
Linux kernel module for PL2303 does support all speed that chipset could provide.
/NOTE: DIFFERENT PL2303 HAVE DIFFERENT CAPABILITY AND FEATURES/
So to achieve a given speed of 230400Kbps simply pass the number to PPPD and
thats all, now if you want a step by step instructions then buzz me again :help: .
These are the options my script pass to PPPD while using RCONNECT.
chandaal@rudra:~ $ ps ax | grep pppd | grep -v grep
5686 ttyUSB0 Ss+ 0:00 pppd /dev/ttyUSB0 230400 holdoff 5 mru 1460 crtscts nomppe noauth usepeerdns defaultroute receive-all ipcp-accept-local ipcp-accept-remote lcp-max-configure 10 lcp-echo-interval 10 lcp-echo-failure 40 noipdefault persist connect /etc/ppp/rconnect
is it going to work with fedora 4.
i am using FTDI Chipset data cable provided by reliance.
Yes it will, but could you please specify through which app you gonna configure
the PPPD and CHAT sequences. There is KPPP, WVDIAL, FEDORA own networkmanager
and even you could have your own cutom script, according to app you may have
to edit few configuartion files. Though { /etc/ppp/options } is always there to tweak
with.
can some one post the complete step by step info on how to do this on linux
I give a try for generic solution on linux, if you have a query for any
particular distro feel free to buzz me.
for ftdi chipset module ftdi_sio.ko should be compiled in as either module or kernel
embedded part.
To check you're having it or not at your current linux PC type being root
/modprobe -l | grep ftdi_sio/
and check for output if it is then less work to do. BTW if you're having any recent
linux distro like FEDORA or UBUNTU, your card would be identifed and related
driver would be loaded when system boots up.
Now check out which device node driver created by typing
/dmesg | grep ttyUSB/
Here are few generic scripts that could be used on linux, now lots of
modifications could be done so that whole range of linux compatible
handsets can be used using these scripts.
main commands are
ron <phone number> to connect
roff to disconnect
Contents of /usr/sbin/ron
#!/bin/sh
if [ $# -ne 1 ]
then
echo "Error in $0 - Invalid Argument Count"
echo "Usage: rconnect <phone no>"
exit
fi
PASS=$1
USER=$1
pppd /dev/ttyUSB0 230400 user $USER password $PASS linkname rim holdoff 5 mru 1460 crtscts nomppe noauth usepeerdns defaultroute receive-all ipcp-accept-local ipcp-accept-remote lcp-max-configure 10 lcp-echo-interval 10 lcp-echo-failure 40 noipdefault persist connect "/etc/ppp/rconnect"
Contents of /usr/sbin/roff
#!/bin/sh
exec 2>/dev/null
PPPDPID=$(cat /var/run/ppp-rim.pid | head -1)
[ -n $PPPDPID ] && kill -TERM $PPPDPID
Contents of /etc/ppp/rconnect
#!/bin/sh
# A chat script to login to a PPP server.
[ -f /var/run/ppp-rim.pid ] && exit 0;
while [ /bin/true ]; do
/usr/sbin/chat -v -f /etc/ppp/rim-chat
[ $? -eq 0 ] && break
sleep 3
done
Contents of /etc/ppp/rim-chat
ABORT 'NO ANSWER'
ABORT BUSY
ABORT 'NO CARRIER'
TIMEOUT 9 "" ATZ OK-ATZ-OK "AT+IPR=230400" OK "atdt#777"
CONNECT
Add this entry to your /etc/ppp/ip-up.local to prevent dormant timer kick in.
PIDOF=/sbin/pidof
PPP_IFACE="$1"
PPP_TTY="$2"
PPP_SPEED="$3"
PPP_LOCAL="$4"
PPP_REMOTE="$5"
PPP_IPPARAM="$6"
$PING -i 5 -B -I $PPP_IFACE $PPP_REMOTE >/dev/null &
echo ($PIDOF ping) > /var/run/ppp/ping.pid
Add this entry to you /etc/ppp/ip-down.local
PINGID=$(cat /var/run/ppp/ping.pid)
[ -n $PINGID ] && kill -QUIT $PINGID
is it going to work with rconnect script provided by reliance?
by modifying baud rate to 230400?
Yes, provided that required kernel module and associated device node is available.
that would be real cool dude...
i was checkin out the link u had given and it was ...errm way over my head sad5.gif ...didnt understand much sad.gif
yes, prolific - thats the one i have... hmmm, actualy im connectin thro a com port now, but i have a usb-cable extra (both grey) ...besides, if im gonna get 230 kbps, i woud proly buy an 'original' usb cable... ;)
and yes, i think the baud rate is change-able in 2030...
do let us know if it works with grey market cables...
For your problem i am sending this file to all who wanted to Use baud rate 230,400 from LG RD2030 by using a cable without FTDI chipset
By replacing this given file to file in the folder LG Usb/Drivers/LG/LGSerial/LG USB MODEM/MDMGEN_2K
you can replace only after downloading setup of rconnect lg rd2030 usb from the Reliance Web Site. :signthankspin:
Salute Me.
and plz send me firmware and .dll file of LG RD2030
MDMGEN_2K.rar
