kagashe
Mandrake Linux 9.1 Please Help Me.
I have HP/COMPAQ Presario Laptop Model 2514AT in which Mandrake Linux 9.1 is installed through CDs supplied by HP.
I have purchased GTRAN GP-4020 handset, downloaded the software available on Relianceinfocom site and tried it. It is not working.
My operating system is able to detect the modem and putting it at /dev/usb/acm as ttyACM0
The Relianceinfocom software tries this device in /dev/input
I have tried to change it to /dev/usb/acm but I am getting an error that pppd could not use this device and proceed further.
I have KPPP dialer and when I try to querry the device I am not able to open the modem. It is possible that there is a lock on the modem. How to solve it? If I can querry the modem through kppp I can try the settings suggested in the sticky post for Fedora.
I found this forum on google search and registered here.
Please help me.
kagashe
NB I have tried the handset on my friends PC on WindowsXP and the RConnect dialer worked fine and I could use my mobile # to log in and surf.
After writing the post I tried once again with RConnect software of Relianceinfocom. The device was /dev/usb/acm/0 and not ttyACM0. I changed it and now it is working.
Now my problem is speed. I am getting a speed of 31 Kbps only.
<TOPIC MOVED!>
Edited by Vishal Gupta
What DTR speed you opt for rconnect script, I guess by default it's set to 115200, change it to 230400.
31Kbps means around 4KBps, is it the maximum speed you're getting all the time ?
BTW also change MTU and MRU
MTU == 576
MRU == 1460
These settings are optimal for rconnect.
Cheers .........................
