kallan 0 Report post Posted June 26, 2005 Is it possible to charge the LG 2130 mobile phone while you browse using R-Connect? I know this feature is available in LG 2030. But not sure about LG 2130? If this feature is not available in LG 2130, then how long can I browse the internet without charging? Share this post Link to post Share on other sites
Arun 795 Report post Posted June 26, 2005 I guess there are data cables available which allow you to charge the handset from the USB port and simutaneously use R-Connect. Share this post Link to post Share on other sites
deepu 0 Report post Posted June 27, 2005 LG 2130 and LG 2030 use the same data cable.. So a USB charging cable for 2030 should also work with 2130.. Do not have more experience on this as the cable i have is not of the charging type!!! Share this post Link to post Share on other sites
harshonline 0 Report post Posted February 9, 2006 LG 2130 and LG 2030 use the same data cable.. So a USB charging cable for 2030 should also work with 2130..Do not have more experience on this as the cable i have is not of the charging type!!! Hi, I have LG 2130 and like to ask..... Do all USB data cables support charging while surfing. Or do i need to ask for a special one. will USB purchased from grey market do that? I currently use serial and it dosent charge. Also my battery run for 3.5 hours after full charge while surfing. is this ok or should i go for a new one. Thanks in advance Share this post Link to post Share on other sites
poppypap 0 Report post Posted August 10, 2006 The battery never run out in case of data cables provided with charging facility. Share this post Link to post Share on other sites
