Sundar
Lg Link
Hi
i bought this lg software from local dealer and only desktop lite is working with my cell but whenever i try to connect the LG link started it is saying that check the connection. can anyone helpme how to rectify this problem?
check for LG SYNC icon running in your task bar right click on that press exit try again.... You will be done.
Actually LG desktoplite is blocking the port...
