naveenagg
Problem With Lg 340 Fwp
I was using LG 340 FWP on windows XP and it was working fine. Recently I tried to install PC suite for Nokia 6225 CDMA. After installation I have not been able to connect using LG 340. I get the message that Modem is not connected. I tried to reinstall Rconnect. It detects the phone but is not able to install modem driver. Is there any work around? Is it possible to remove rconnect and the LG 340 drivers installed before going for a fresh rconnect installation.
Regards!
Naveen
  lavkesh said:
hi just go to the help section of the rconnect dialer and look for topic uninstall follow and jobs done
35113[/snapback]
Hi
Thanks! I was able to make it work by adding it as a new standard 33600 modem. After adding the modem it automatically got dailed through rconnect.
Naveen
