ankurktr
Lg Lsp 340e R Connect Issue
I am using LG LSP340e for accessing internet through my laptop.
I am using a USB to serial port converter cable.
All the setup of modem and cable driver is setup perfectly without any
errors.I am using win XP professional with SP1a.
When i connect to internet, it does get connected and some data transfer take place for initial 1 min.In that one min I am able to connect yahoo messenger
and probabaly open google. But after about 1 min, the data transfer rate is 0.0bytes/sec. !!!! :D When the internet is connected, Iable able to do "ipconfig" and see that the ip is being allocated to my machine from the reliance server.
I am not able to figure out whats wrong....even "query modem" from devie manager modem properties is working fine.There seems to be no prob in installation of drivers /data cable !! Device managarer shows all green.!!!
Anyone ...any help!!!! email pls ankurktr@yahoo.com
May be some virus problem...
Try to update ur system with SP2 & other updates.
It should solve ur problem.
35559[/snapback]
well in the mean time I posted this, I had updated my laptop with SP 2 as well.
problem persits!! I don't know whats wrong..It gets connected successfully still
speed is zero after 1 min.!!!!
The signal in teh phone is strong too(4 bars) !!! What to do.
The data cable is new and i have tested it with my friends computer.It works well.!!
Could it be a phone issue!!!???I am kindof frustrated with it.!!
Why don't u try to connect net with ur phone on ur friend's comp as u did for checking the cable?
U can find in this way whether the problem is with ur phone or with ur comp..
So try it.
Well Ankur, USB cables with the LSP-340E have always been a problem. One of my friends is facing a problem wherein the phone keeps disconnecting for now reason whatsoever, and very often the connection just dies out (as in your case). This needs to be told to Reliance customer care technical section. File a complaint (and make a note of the number too).
raise the buad rate inthe virtual com port to 112500 from 9600 and set the flow control to hardware it will surely help u...reply soon
I am facing similar problem on LG 5120 it works fine for 2-5mins and then goes into Dormancy mode. I have to disocnnect and connect. Sometimes it works fine for an hour but most of the times it goes into dormancy and never works within 2-5mins.
Getting really frustated and thibking of buying r-connect card but damm webworld in bomaby says cards are not in stock as of now.
Ankur !
We r in the same boat.
I have preciesly same enviornment as u have, LG-LSP-340E, WinXP and same problem of dormancy.
In my case, sometimes it happens very often at every 10/15 min and sometimes it stays connected for hours. I really don't understand what's causing it.
Trying out different options, but no sucess yet.
Pls. let me know, if u find any solution. if I found, I will post here.
Cheers !
Jigs
try to continually ping a server......
cheers
Ashok
Guys,
Have any of you guys been able to resolve this issue?
I'm facing similar problem with my LG5130.
Getting really frustrated with the issue.
Please help.
regards,
Hareesh
I too face the same problem for this i open google in Opera and set to automatically loading 10 secs
right click > Reload every > Enable
and set the secs.
Only that way it work else 0 0 0 0 0 0 0 0.
try it out guys its same as pinging but pinging may ban you on that site as the request is every sec...
From the number of people saying here that they also have the same problem, (I also) we can understand how the customer care team is working. For me I am facing problem for last 6 months. They are not sincere to solve this. Idiot Reliance peoples.
Guys,
Please help.
regards,
Hareesh
