sahil2000ind 0 Report post Posted July 19, 2005 Last nite wheni was at my bed playing with my n191 and accidently i pressed MENU+6+* i got one option FIELD SERV that ask for a 6 digit code and i pressed 123456 then some more option came out like 1. Debug Screen 2. Test call 3. Voice SO 4. Port Map 5. Data Scrn 6. Reverse RC 7.My Phone No so i ask all u ppl to find out more on all these things i have tried it only on my sam n191 Share this post Link to post Share on other sites
anujit 0 Report post Posted July 19, 2005 I think thats an old trick works for Samsung 563 too (Menu - 8 - *) and password is 123456. If you go to the debug screen you get alot of number codes on the screen I think some of them stand for battery and signal strength etc. Some numbers keep changing rapidly, some slowly others are static. Can anyone decode the debug screen? Share this post Link to post Share on other sites
ashoksoft 83 Report post Posted July 20, 2005 I think thats an old trick works for Samsung 563 too (Menu - 8 - *) and password is 123456.If you go to the debug screen you get alot of number codes on the screen I think some of them stand for battery and signal strength etc. Some numbers keep changing rapidly, some slowly others are static. Can anyone decode the debug screen? 36046[/snapback] Just reached back yesterday.... now back in attack mode. Got a 191 with me... lemme try my luck (well the internet is also damn big.... I might get a lil help from accross... he he ) Cheers Ashok Share this post Link to post Share on other sites
anujit 0 Report post Posted July 20, 2005 Yahoo! Ashok's back! And Ashok - you might want to have a look at my gmail posting too (hint hint)!!!! Share this post Link to post Share on other sites
Shabz 8 Report post Posted July 20, 2005 Saahil thats a very old code discussed before also in the rimweb discussions Mods may remember it I think it was removed when the CL*** topic was hit and removed Share this post Link to post Share on other sites
ashishbabu 1 Report post Posted July 23, 2005 There is a hidden menu in Samsung A563. When we type menu+8+* 1. Debug Screen 2. test calls 3. CDMA Only 4. Voice SO 5. SIO Config what is the use of above options can anybody know plz tell me. Thanks in advance. <<Topic Merged>> Share this post Link to post Share on other sites
Puneet 0 Report post Posted July 23, 2005 The screen shows the debug menu, and also some information regarding the signal strength, SDCA, service provider code etc. Also allows one to make some test calls on the network. Had seen a network guy using it when I had complained regarding network problem in my area. Share this post Link to post Share on other sites
Utsav 0 Report post Posted July 23, 2005 GR8 work guys! Pls keep posting... Share this post Link to post Share on other sites
ankitengr 0 Report post Posted July 23, 2005 GR8 work guys! Pls keep posting... 36351[/snapback] Warnning : Don't try to change anything. The handset can be useless. Try this code : 47*869#08#9 Share this post Link to post Share on other sites
ashishbabu 1 Report post Posted July 23, 2005 GR8 work guys! Pls keep posting... 36351[/snapback] Warnning : Don't try to change anything. The handset can be useless. Try this code : 47*869#08#9 36366[/snapback] What is the effect of above code. Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted July 23, 2005 Read here: Cdma Secrets / Secret Codes Share this post Link to post Share on other sites
