ssr
R-connect Problem In Rd2130
Hi all,
Yesterday the batery power was over in my phone and after 4 hours i again started charging it.
and after 15 minits when I tried to connect to net no responce from phone.
When i press dial in windows nothing apears in phone display. :help:
I just removed my phone from cable and put my brothers RD2130. and it works fine , so that means that cable and setting are fine from System.
Any one faced the same prob?
Hi all,
When i press dial in windows nothing apears in phone display. :cry:
Nope. I've never faced this problem. Try charging the phone for atleast 30-45 minutes before you try connecting. A 15-minute charge may not be enough.
Also, after charging, just reboot your phone i.e. switch it off and then switch it on. Then try connecting to the Net.
Sometimes, these simple things work. :help:
