prshah 0 Report post Posted August 5, 2005 Hello all, I have manually setup my RConnect DUN connection. I have used the "at+crm=2..." commands, and set the dialup number as "#777" and put username and password as my phone number. It connects successfully, assigns IP address and assigns DNS addresses as: DNS 1) 97.253.25.9 DNS 2) 97.253.25.10 However, when I try to browse, no web addresses (http://www....) are resolved. Even stranger, whatever web address I try to ping, I get the same IP address: Eg: === ping www.google.com Pinging www.google.com (24.240.159.229) with 32 bytes of data Request timed out. ping www.yahoo.com Pinging www.yahoo.com (24.240.159.229) with 32 bytes of data Request timed out. ping www.rimweb.com Pinging www.rimweb.com (24.240.159.229) with 32 bytes of data Request timed out. Can anyone connect to RConnect and tell me the DNS settings that they are getting? Any ideas/suggestions on what may the be the problem? Config: Acer TravelMate / Win XP Home / Nokia 6225 ==> No special setup, alternate dialup connection works fine. Cheers, PRS Share this post Link to post Share on other sites
Utsav 0 Report post Posted August 6, 2005 Hello all,It connects successfully, assigns IP address and assigns DNS addresses as: DNS 1) 97.253.25.9 DNS 2) 97.253.25.10 Cheers, PRS 37292[/snapback] Are u being assigned with same IP/DNS? Share this post Link to post Share on other sites
prshah 0 Report post Posted August 6, 2005 Hello all,It connects successfully, assigns IP address and assigns DNS addresses as: DNS 1) 97.253.25.9 DNS 2) 97.253.25.10 Cheers, PRS 37292[/snapback] Are u being assigned with same IP/DNS? 37351[/snapback] Nope IP address keeps changing. DNS addresses do not change, but something is fishy. Can you connect on R Connect and tell me what DNS server addresses you are getting? Share this post Link to post Share on other sites
prshah 0 Report post Posted August 7, 2005 I have manually setup my RConnect DUN connection. I have used the "at+crm=2..." commands, and set the dialup number as "#777" and putconnects successfully, assigns IP address and assigns DNS addresses as: However, when I try to browse, no web addresses (http://www....) are resolved. Even stranger, whatever web address I try to ping, I get the same IP address: 37292[/snapback] Thanks everybody, problem solved cheers and best luck, had to use "at+crm=1"!! PRS Share this post Link to post Share on other sites
