harry69in 0 Report post Posted August 27, 2005 i got this LG RD6130 and trying to install r-connect software. it installs the driver but when it prompts to connect the phone to PC and to wait for "windows hardware wizard", the wizard appears but detact the new hardware as "usb data cable".as for my knwoledge it must be a "modem" not a "cable". anyways if i proceed with the "usb data cable" it does not locates any driver to install. the only mistake i might have done is i connected to phone before i started installations! any ideas anyone?? thanks in advance for yours help. my regards harry Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted August 27, 2005 Try following steps: Restart ur phone. Start the installation wizard. Connect the phone only when the wizard asks for it. It should help U... Share this post Link to post Share on other sites
deepu 0 Report post Posted September 20, 2005 This happened for me also... You just restart the system once more and try once again. It should work fine!! Share this post Link to post Share on other sites
RajanPERT 0 Report post Posted September 20, 2005 harry69in! Are your problem solved, Please share ur experience with US. Thanks and Take Care! Share this post Link to post Share on other sites
Pankaj Verma 0 Report post Posted September 20, 2005 harry whether you are using geniune LG data cable or other cable? Share this post Link to post Share on other sites
