pSantosh 0 Report post Posted August 29, 2005 I have noticed something strange happening to my computer after using the Rconnect for a longer duration of time. The system behaves like character 'm' is continuously pressed. I have Norton Anitivirus on my machine and the files are uptodate. I use the internet the entire day in the office network and there is no problem. Even at home if I use the dialup no issues. But after using Rconnect for longer durations, I am in trouble. Help. Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted August 29, 2005 Pls be more specific about ur problem! What problem exactly r u facing? May be its becauz of faulty keyboard! So pls be more clear... Share this post Link to post Share on other sites
pSantosh 0 Report post Posted August 29, 2005 Pls be more specific about ur problem!What problem exactly r u facing? May be its becauz of faulty keyboard! So pls be more clear... 39348[/snapback] It is not a faulty keyboard Let me explain.. My laptop is running absolutely fine and there is no hardware issue. After I use the RConnect feature for longer durations of time, my system behaves as though the character 'm' key is pressed continuously. i.e. if I am in a text editor say notepad, the character 'm' is continuously typed. After ths if I run the virus scan of the entire system, it starts behaving ok until the next time I use RConnect. I pinpoint on the RConnect features because on an given day I use the internet through many different modes i.e. broadband and dialup through a normal landline. These do not give me any problem. But RConnect does. I hope you are clear about the problem that I encounter. Share this post Link to post Share on other sites
ashoksoft 83 Report post Posted August 29, 2005 Wow ! does reliance have some magic programmes ? are u dialing using the R-Connect dialer ? maybe there is some conflict .. who knows cheers Ashok Share this post Link to post Share on other sites
Arun 795 Report post Posted August 29, 2005 Can you try creating a dial up networking connection for R-Connect and then use it, instead of Reliance's R-Connect dialer and see if there is any difference ? Share this post Link to post Share on other sites
TCP/IP 0 Report post Posted August 30, 2005 Try AVG Anti Virus or something. Use Norton for a false sense of safety. Share this post Link to post Share on other sites
anujit 0 Report post Posted August 30, 2005 I disagree TCP. Norton & Trend are the two best AVs around. Only problem is NAVs heavy footprint and slugish performance that pi$$e$ me off! Its way faster than most in terms of time-to-update search menthods, configs etc. Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted August 30, 2005 Do what Arun has suggested! It'll surely work. And pls tell the result... Share this post Link to post Share on other sites
RajanPERT 0 Report post Posted August 30, 2005 This may be due to the some type of malfunction of the device or r connect program. As u say your keyboard Working fine in other condition. First describe me these things. 1. How u connect your phone to the system (Through Serial port or use of USB) 2. Which OS u are presently using. 3. There is any other modem or communication device is also attached to the system, if any then describe its type and connection (Port). 4. How many hours after u face this problem. 5. Also try to scan your system by the Lavasoft Ad Aware or any other spyware software. We will try our best to help u. Thanks and Take Care! Share this post Link to post Share on other sites
webmaster1963 0 Report post Posted August 31, 2005 4-5 days back i got the virus " hacktool.rootkit " while using rconnect. this can not be removed with norton so i have to format the system. as soon i start the rconnect sending bytes were thrice rhan receiving bytes. be careful while using rconnect guys Share this post Link to post Share on other sites
