mhimanshu2003
Sb Data Cable Require A Usb To Serial Converter Dr
hi
Does the USB data cable require a USB to Serial converter Drivers . I have a USB data cable ,but not sure whether I should install as Serial or as USB
any help willbe apreciated.
Mayank
My question is : Is the USB data cable which is avaible in the market a pure USB device or it contains a USB <-> Serial Convertor?
Will this work if I donthave any Serial Ports on mY laptop
hi,
the cables which are generally available in market do need you to install USB TO SERIAL converter because all LG phones require serial connection to computer hence you need some converter driver.
-max
The cables that u get in the market generally have a RS232 Chip based, Serial to USB adaption followed... precisely specifying the need for a driver of the chip
Cheers
Ashok
