ksudeep 0 Report post Posted October 11, 2005 hello, this is my very fist day @ this forrum and also to PC sync. I carry LG RD2030. can anybody explain me a very step by step guide to connect with my PC ? if would be very much helpful if you mention the name & version (+link to download, if possible) of the softwares to be used ? after following some posts, i tried with BitPim & QPST but failed to get connect. thanx a lot. Share this post Link to post Share on other sites
ashoksoft 83 Report post Posted October 12, 2005 More details from ur end Sudeep... what datacable are u using? Serial or USB and other such issues... as to how U TRIED to connect.... and someone here will surely get a step by step manual out for u.. Share this post Link to post Share on other sites
ksudeep 0 Report post Posted October 12, 2005 #1. am using USB data cable. #2. i tried to connect with BitPim & QPST. #3. i also found one link on this forrum which let me upload & download only the phonebook on PC. but i want much more info. Share this post Link to post Share on other sites
Utsav 0 Report post Posted October 12, 2005 Such posts already exist. Please use the search button. You can check http://www.rimweb.in/forums/index.php?show...0&hl=2030++Sync too. Share this post Link to post Share on other sites
ksudeep 0 Report post Posted October 13, 2005 hi Utsav, i checked the link but its all filled negative feedback. tell me, is it not at all possible to communicate the twos with USB port ? do i have to go for serial cable ??? Share this post Link to post Share on other sites
RajanPERT 0 Report post Posted October 13, 2005 Yeah! USB cable is not working so great, it will very difficult to a new user to install and use it. As i found till now. And i did not found any solution for this. You can use Serial Cable it works great but speed decreased during R Connect. I think USB cables speed is fater than Serial Cable. First install the Serial Cable and then follow the different threads available at RIMweb for other task. Thanks and Take Care! Share this post Link to post Share on other sites
