asher 2 Report post Posted October 18, 2005 I am in trouble my UIM loked asking PUK code Anybody help. Share this post Link to post Share on other sites
chandrababa 0 Report post Posted October 23, 2005 hi has your problem solved?? if not then just try out "000000" and press ok . the same problem was solved by using above solution. see if it works with you... and let me know.. bye take care.. Share this post Link to post Share on other sites
