bap0551
R Connect Problem With Gtran
I HAVE GTRAN GCP 4020 WHICH DOES NOT WORK WITH R CONNECT. I HAVE INSTALLED THE SOFTWARE ON SERVERAL PC/OS. THE MOMEMNT I PUT USER ID AND PASSWORD AND SAY CONNECT, THE PC EITHER HANG UP OR RESTART WITHOUT AND WARNING MESSAGE. SOMEONE PLEASE HELP ME. :)
R u have any problem to access the PC Sync soft of GTRAN. If u did not install it, please install it and check, it is working or not. If it is, check ur modem, for this use step 3 describe in following link http://www.rimweb.in/forums/index.php?showtopic=4540&st=0#
Keep Posting at RIMWEB.
Thanks and Take Care!
