abhay 0 Report post Posted December 4, 2005 may be there is a way to attach the no-ip service and the web-server(ie port 80) through MTNL connection is all incomming/outgoing of no-ip and the webserver through MTNL and rest through sify & and yup i think that is possible, isint it Share this post Link to post Share on other sites
StaticElectricity 8 Report post Posted December 4, 2005 ooh boy, i really didnt get what you ppl are trying to do, but as far as i can say, set up a dummy page at the MTNL IP,use some scripting such that the dummy page finds out the SIFY Public ip, and redirects all the hits to your SIFY ip. I guess thats all you can do. Share this post Link to post Share on other sites
abhay 0 Report post Posted December 4, 2005 whatever u said could work dint try it thought seems to be some kinda technical glich there but even if it works it wont solve the problem of actully having two diffrent connection one with public ip and second with pvt ip and most of the traffic should go from the pvt one Share this post Link to post Share on other sites
adwait 0 Report post Posted December 4, 2005 may be there is a way to attach the no-ip service and the web-server(ie port 80) through MTNL connectionis all incomming/outgoing of no-ip and the webserver through MTNL and rest through sify & and yup i think that is possible, isint it 49146[/snapback] Possible......yes, how, that's what we are trying to figure out. Lets see what linuxguy thinks of my last idea, cuz I don't really know much about the internal working of TCP/IP. Share this post Link to post Share on other sites
abhay 0 Report post Posted December 4, 2005 (edited) linux is true ! hey whats ur real name by d way if i connect to one ip address then i have to communicate with that ip only what we actully need is all mtnl connection should be on MTNL and all sift connection through sify 1) both should not mess with each other 2) a way to keep specific appz to comunicate with perticular NIC (as in no-ip and all kinda webservers <-- all outgoing and incomming connections through from these appz through one (MTNL NIC)) Edited December 4, 2005 by abhay Share this post Link to post Share on other sites
linuxguy 0 Report post Posted December 4, 2005 abhay, you can run the webserver on the MTNL IP and surf the internet on the Sify IP. That can be done without a problem. But then data exchange on the MTNL IP will be counted and since you have a limit, you might exhaust your limit pretty quickly if your webserver hosts big files Guys, the problem with running a webserver on the Sify IP is that abhay is NATed behind the router's IP. For example: Sify's router -> External NIC = 212.x.x.x Internal NIC: 10.0.0.1 Now, all customers connect to Sify's internal NIC which means they all have IPs in the range 10.0.0.2-10.0.0.254. Sify's router handles authentication, DHCP and NATing. Since it doesnt port forward all the ports, what happens is that the request sent to the Sify's external IP wont be forwarded to abhay's internal IP. Hence, even if abhay knows the external IP of Sify's servers, it wont be of any use lest sify configures a DMZ or Port forwarding. Sify can setup a DMZ for Abhay or they can forward selective ports to his computer but I dont think they will be willing to do that Life is complicated Share this post Link to post Share on other sites
abhay 0 Report post Posted December 4, 2005 (edited) aree linuxbhaiya woh to sabko pata hai ki yeh mera problem lets stop describing the prob and get to work and get a solution for it if it is solved it can help anybody who wants a cheap PUBLIC IP SOLUTION i mean who gives a public ip for just RS 80 / month MTNL ka dabba kuch toh kaam ayega PS rs 80 is mim chages then rest the charges are as per usage Edited December 4, 2005 by abhay Share this post Link to post Share on other sites
linuxguy 0 Report post Posted December 5, 2005 abhay, the per MB charge is what s**ks. Otherwise i would've gone for MTNL myself. Why do you think I keep ranting about ****ty broadband in India? Share this post Link to post Share on other sites
adwait 0 Report post Posted December 5, 2005 abhay, you can run the webserver on the MTNL IP and surf the internet on the Sify IP. That can be done without a problem. But then data exchange on the MTNL IP will be counted and since you have a limit, you might exhaust your limit pretty quickly if your webserver hosts big files 49199[/snapback] I don't see how you can do that either? You would still have to change the routing tables right? And if you change them, they work on both connections right? Share this post Link to post Share on other sites
abhay 0 Report post Posted December 5, 2005 (edited) abhay, the per MB charge is what s**ks. Otherwise i would've gone for MTNL myself. Why do you think I keep ranting about ****ty broadband in India? 49271[/snapback] my webserver would be running on MTNl so max datatransfer would be 30 - 40 mb a month so my bill would reach max 150 RS that good enough for a256 connection abhay, you can run the webserver on the MTNL IP and surf the internet on the Sify IP. That can be done without a problem. But then data exchange on the MTNL IP will be counted and since you have a limit, you might exhaust your limit pretty quickly if your webserver hosts big files 49199[/snapback] I don't see how you can do that either? You would still have to change the routing tables right? And if you change them, they work on both connections right? 49276[/snapback] i think we can modify routing table in such a way that some appz work with one NIC and some with other i dont know how it is done though . theorytically it is possible Edited December 5, 2005 by abhay Share this post Link to post Share on other sites
adwait 0 Report post Posted December 5, 2005 Ok sorry for off topic posting........but I am really remindef of this quote "Theory is when you know something, but it doesn't work. Practice is when something works, but you don't know why. Engineers combine theory and practice, nothing works and they don't know why!!" Share this post Link to post Share on other sites
linuxguy 0 Report post Posted December 7, 2005 adwait, you still havent gotten it. There isn't any need to modify the routing tables. The Apache server can bind itself to the MTNL IP. While we can set the default gateway to Sify, so all other apps will communicate through Sify while Apache does through MTNL. Share this post Link to post Share on other sites
adwait 0 Report post Posted December 8, 2005 aaah! aisa hai kya.........never knew that. Hmm......something to tinker with in the holidays (only 2 papers left......yay!!) Share this post Link to post Share on other sites
abhay 0 Report post Posted December 8, 2005 bhaiyoon aapas mein hi discuss karna hai ya iss windows wale ke problem bhi suljhana hai Share this post Link to post Share on other sites
linuxguy 0 Report post Posted December 8, 2005 Abhay, dont ask me to guide you in Windows. I absolutely dont use windows :| Share this post Link to post Share on other sites
cracker 0 Report post Posted December 26, 2005 I have a simple solution for u. install Microsoft’s virtual pc and run 2 pc in 1 download virtual pc from Microsoft’s web site. If u don’t like ms stuff than u can go forVMware Workstation 5 It is virtual workstation. Get its trial version from http://groups.google.co.in/group/desi-tek/...a957181995506f6 it is easy to configure and use Share this post Link to post Share on other sites
abhay 0 Report post Posted December 26, 2005 where exatly are you trying to get @ how will it solve my problems ?? Share this post Link to post Share on other sites
ashoksoft 83 Report post Posted December 27, 2005 Think of this funda... U host a web page... and provide the IP to the world. (consider it is 203.*.*.* - MTNL) And now u wish that when a user requests a page from ur MTNL address, u send him a page (maybe via re-direction) from ur SIFY connection. Aren't we missing something major here??? If u could do the transmission thro ur sify IP, why do u need two connections? (and logically, isn't it simpler to do a simple server-send, rather than a server-redirect?) Cheers Ashok Share this post Link to post Share on other sites
cracker 0 Report post Posted December 27, 2005 (edited) by using virtual pc u can have two or more os @ 1 time on 1 pc u can use sify in 1 and mtnl in other to run a webserver Edited December 27, 2005 by cracker Share this post Link to post Share on other sites
abhay 0 Report post Posted December 27, 2005 (edited) ok did it got VMware and virual pc cracked so now some R&D left to do on it hmm thx for d idea buddy! will surely try on it hey btw isint there any lesser memory consuming way out ! ??? Edited December 27, 2005 by abhay Share this post Link to post Share on other sites
ashoksoft 83 Report post Posted December 28, 2005 try the yonger bro of them all .."bochs system emulation" cheers Ashok PS : it is free too (opensource)!! Share this post Link to post Share on other sites
linuxguy 0 Report post Posted December 28, 2005 eh? i dont understand how exactly will VPC solve his problem. Forget solving problems, it is going to complicate them further. And I have told this plenty of times, what Abhay is trying to achieve is _not_ possible with TCP/IP Share this post Link to post Share on other sites
cracker 0 Report post Posted December 28, 2005 ok did it got VMware and virual pc cracked so now some R&D left to do on it hmm thx for d idea buddy! will surely try on it hey btw isint there any lesser memory consuming way out ! ??? minimum requirement 256mb ddr ram p4 2.4 ghz 256mb freespace Share this post Link to post Share on other sites
amitbt22 2 Report post Posted December 28, 2005 Will Amd Athlon xp 64bit 2800+(1.81Ghz) with 512mb ram do? Share this post Link to post Share on other sites
abhay 0 Report post Posted December 28, 2005 hmm no wonder VMware hangs up my XP with 1 gig of ram and 1.7 celeron Share this post Link to post Share on other sites
