ketan_kunde
Nokia 3125 R-connect Install Problem
I have a weird problem with R-Connect installation for Nokia 3125. I use an original Nokia CA-42 cable and installation s/w from Reliance website. Whenever I try to install, it reaches the point where it asks to connect the handset. After installation of the handset drivers, the"Next" button never gets enabled. This has also happened to me in the past with an LG phone. Is there any way to manually install the phone (Nokia) and connect with the windows dialer instead of using R-Connect s/w?
Just call the costomer care center and they will tell you the command for modem set up. There is no need forRconnect for NOKIA 3125...I am suing CA-42 cable with NOKIA 3125........
hey ketan !!
i have a nokia 3125 too and i was having the same problem .. ditto !!!
i called up the customer care but they had no clue .... but somehow at a webworld a cust. representative knew the solution.... he added some special comand in extra modem intialization command... thats it and it started working. i don have the command right now but i will post that in the night .... :)
oops i noticed later that this post is quite oldd. u must have got the soulution .. please tell me also how it was solved thanks.....
Edited by rimmy
I hope this is the extra initialization command that is needed to be entered in the Advanced tab of Modem properties...
(AT+CRM=1;+CSO=33)
