saurav123 1 Report post Posted December 7, 2005 Dear friends, I got a cordless speaker phone as gift last year of Panasonic brand, model no is: KX-TC1035BXB , it’s a black color phone; keypads are present on handset and on base (main machine). Last week I gave my set to a local mechanic for changing its battery n charger, and after this my dial tone is now set to PULSE, how can I change it to TONE, there is no slide switch/button for changing PULSE/TONE on side of set. My other parallel handset is working fine with tone dialing. I’ve lost its manual book. I’m giving its keypad structure here: ================================================== (Talk/on/off) (AUTO) (INTERCOM) [1][2][3] [4][5][6] [7][8][9] [*][0][#] (REMOTE SP) (FLASH) (LOUD) (REDIAL) (PROGRAM) (PAUSE/RINGER) (CHANNEL) ================================================== Keypads are same on handset and main base machine. TONE text is printed on [*] button. 3 led indicators are given, for recharge, intercom, talk. Some texts are printed on base machine: EXTRA RANGE PLUS, SOUND PLUS Plzzzzzzzzzzzzz reply soon…… its takes too much time to call by pulse dialing, at present I’m using * button before dialing number for tone dialing. Share this post Link to post Share on other sites
akg7091 4 Report post Posted December 7, 2005 on all phones, there is a small switch on the base unit where you can set it to pulse/tone. just look at the side/bottom of the base unit. There will be a switch with p/t on either sides. set it to t. Share this post Link to post Share on other sites
Chirag 5 Report post Posted December 7, 2005 As an alternative, before you start dialling the number, press * and then dial the number. This was the old way, to switch to Tone! Maybe that helps! Share this post Link to post Share on other sites
raccoon 53 Report post Posted December 7, 2005 on all phones, there is a small switch on the base unit where you can set it to pulse/tone.just look at the side/bottom of the base unit. There will be a switch with p/t on either sides. set it to t. 49438[/snapback] No, it is not so on all phones! I have a phone on which the signalling method has to be changed thru the console keys. This is how it is on my ph - Press SET key (this may be the PROGRAM key on ur set) Press # key Press 1 for pulse / 2 for tone Press SET key to save This is how it is on mine. May be similar on your set ...or may be quite different. If you tinker around, you might get lucky. But best to try to get the manual. Or ask somone who has a Panasonic... Share this post Link to post Share on other sites
santoshmaharjan 0 Report post Posted March 16, 2007 Dear friends, I got a cordless speaker phone as gift last year of Panasonic brand, model no is: KX-TC1035BXB , it’s a black color phone; keypads are present on handset and on base (main machine). Last week I gave my set to a local mechanic for changing its battery n charger, and after this my dial tone is now set to PULSE, how can I change it to TONE, there is no slide switch/button for changing PULSE/TONE on side of set. My other parallel handset is working fine with tone dialing. I’ve lost its manual book. I’m giving its keypad structure here: ================================================== (Talk/on/off) (AUTO) (INTERCOM) [1][2][3] [4][5][6] [7][8][9] [*][0][#] (REMOTE SP) (FLASH) (LOUD) (REDIAL) (PROGRAM) (PAUSE/RINGER) (CHANNEL) ================================================== Keypads are same on handset and main base machine. TONE text is printed on [*] button. 3 led indicators are given, for recharge, intercom, talk. Some texts are printed on base machine: EXTRA RANGE PLUS, SOUND PLUS Plzzzzzzzzzzzzz reply soon…… its takes too much time to call by pulse dialing, at present I’m using * button before dialing number for tone dialing. Do the following: 1. Press 'PROGRAM' button. 2. Press 'AUTO' button. 3. To select 'PULSE', press # button twice or press * twice to select 'TONE'. 4. Press 'PROGRAM (A confirmation beep will be heard.) DONE Hope it was helpful. Regards, Santosh Maharjan Share this post Link to post Share on other sites
mljubo 0 Report post Posted December 23, 2009 Thanks a lot!You helped me too after few years! Best regards Ljubo Share this post Link to post Share on other sites
ani_meher 42 Report post Posted December 24, 2009 Wow, the longest running thread with the longest spread of posts (2 yrs each between last 3 posts!) Someone should bump this up in 2011. Share this post Link to post Share on other sites
::Hitesh:: 1,763 Report post Posted December 24, 2009 :Contento: Share this post Link to post Share on other sites
neerajchem 0 Report post Posted January 16, 2010 MY DEAR FREIEN RESENTLY I HAVE PURCHAESD SAME MODEL I ALSO FACE THE SAME PROBLEM MY POHNE WAS SET ON TONE AND I WANT TO CHANGE IT TO PULSE SO I SEARCHED THE NET AND FOUND THE SOLUTION THAT IS AS FOLLOWS TAKE THE HAND SET NEAR BASE UNIT ENSURE TALK SHOULD BE OFF PRESS "]PROGREMME"]KEY TALK INDICATOR WILL BLINK PRESS "AUTO" THAN * TWICE AND THAN AGAIN PROGEMME KEY NOW YOUR PHONE WILL BE SET FOR "TONE" FOR PULSE AGAIN PROGREMME+AUTO+# (TWICE ) AND THAN PROGREMME I THINK IT WILL HELP YOU AS I HAVE TRIED IT AND IT IS OK NEERAJ KUMAR GARG INDIA Share this post Link to post Share on other sites
