jchakra 0 Report post Posted December 10, 2005 Hi All, Can anyone suggest me with any tool with which I can keep a log of the Internet Connection used through RConnect. Features like recording the time and date connected and displaying the duration connected. Regards Jaideep Share this post Link to post Share on other sites
rEdshiFt 1 Report post Posted December 10, 2005 DU Meter. Search the forum, im sure u'll find a link. or Google it. Share this post Link to post Share on other sites
ujmvjm 0 Report post Posted December 10, 2005 Check out Magitime. You can get it here: http://www.geocities.com/magistone Share this post Link to post Share on other sites
jchakra 0 Report post Posted December 10, 2005 Actually I am looking for some freeware tool for the purpose... pls help Share this post Link to post Share on other sites
@ksh@T 20 Report post Posted December 10, 2005 DU Meter is the best...do try it!..... download it from here http://dl.hageltech.com/DUMeter-Install.exe Share this post Link to post Share on other sites
jchakra 0 Report post Posted December 14, 2005 ujmvjm said: Check out Magitime. You can get it here: http://www.geocities.com/magistone Magistone is a great tool to record the activities performed through Rconnect. Thanks a lot. I have downloaded DUMeter too, but didn't try it till now. Share this post Link to post Share on other sites
imvikky 0 Report post Posted December 14, 2005 Even I have been using Dumeter for long now... It eats slightly into the system speed but is good Share this post Link to post Share on other sites
Honest 836 Report post Posted December 14, 2005 DU Meter is the best choice for accuracy. Share this post Link to post Share on other sites
