Arun
So U Think U R Very Good At Maths...?
Three is equal to four....
Theorem: 3=4
Proof:
Suppose:
a + b = c
This can also be written as:
4a - 3a + 4b - 3b = 4c - 3c
After reorganizing:
4a + 4b - 4c = 3a + 3b - 3c
Take the constants out of the brackets:
4 * (a+b-c) = 3 * (a+b-c)
Remove the same term left and right:
4 = 3
Four is equal to five
Theorem: 4 = 5
Proof:
-20 = -20
16 - 36 = 25 - 45
4^2 - 9*4 = 5^2 - 9*5
4^2 - 9*4 + 81/4 = 5^2 - 9*5 + 81/4
(4 - 9/2)^2 = (5 - 9/2)^2
4 - 9/2 = 5 - 9/2
4 = 5
Howzat ?!?
Good one
You may all know this:
With one strike you need to solve this equation:
5+5 = 545
By adjusting only one digit in the following equation you need to solve:
102 - 2 = 98
This is a fallacy. Since a+b=c, a+b-c=0. The above equality holds only because both the sides are zero. And when a multiplication by zero term is involved, you cannot equate the coefficient of the terms. This would amount to saying 1*0 = 0, and also 10000000000* 0 = 0 hence, 1 = 10000000000 (or whatever).
4 - 9/2 = 5 - 9/2
4 = 5
(4 - 9/2)^2 = (5 - 9/2)^2 = 0.25
Square roots of 0.25 are +/- 0.5
Similarly, square roots of (4 - 9/2)^2 are +/- (4 - 9/2) and (5 - 9/2)^2 are = +/-(5 - 9/2)^2.
4-9/2 = -0.5 and 5-/2=0.5.
You are equating the wrong roots. Correct way would be -(4-9/2)=(5-9/2) or (4-9/2)=-(5-9/2)
Expanding the brackets in one of the above
-4 + 9/2 = 5 -9/2, perfectly correct and now you cannot cancel out 9/2, hence 4 is not equal to 5.
IIT brains at work :help:
really a good theorm and a nice reply.........i mailed this to all my friends
IIT brains at work :blink:
We used to solve these kinda things while I was in class XI. Long ago, and I was not an IITian then :help:
sharp, puneet ;)
Thanks. :grin:
wonder what in puneet is sharp :)
Good one
5+5 = 545
102 - 2 = 98
The answer of first one is, draw one verticle line to the top left of + sign, so it becomes 4, like
it is _|_ , draw a line to make it |_|_ , ie 4. (pls ignore the 'i's in next line. It's not taking spaces.
i i i i i | i i i i i i i i i i i i i i i i i i i i i i i i |
As for the second one, I guess the 'adjusting' is making the 2 as 4. ie 102 - 4 = 98. But I am not sure about this one.
Edited by ani_meher
Good one
5+5 = 545
102 - 2 = 98
I think, he meant just moving around the digits, not changing a digit... so it's very likely:
10^2 - 2 = 98 (i.e. just move the 2 in 102 to the exponent).
Yes, this seems to be the right answer.
SexyGurl & Ani Mehar both are correct!!!! Keep it up!
