Naveed
Connect One Pc To Another Using Rim
hello evry one
it is possible to connect through one pc to another by using Relience LG 2030
If any one do this plz tell me
as dialup, other networking is possible
Edited by Ashokjp
As far as i know,
At present two pcs cant be connected because data services are not yet available..
Even dialup connection cant be made to other pcs..
Only dialup connection to reliance server is accepted...
hello evry one
that kind of connection using direct dial from reliance phone to reliance phone is currently not possible since reliance does not allow data calls over their network.
but it is possible to make a direct connection over the internet(which may not be the solution,but i felt it necessary to mention)
static, i meant connection thru internet..there are wide variety of softwares available on the web...
Yes static, once Both the pcs are connected to the internet, then they can be connected using some software like Real VNC ( http://www.realvnc.com)
And thats what static meant by
But that is really going to be a costly affair ...
And hence not perfect the solution to this......
So that means, u ppl want to establish a direct connection between two computers via phone? And how does that happen generally via regular Modems? what s/w do we need if we connect via a dial-up connection?
You can connect two pcs directly using simple hyperterminal...
There are many utilties available too for this purpose.....
But it does not work with these phones
via general modems we need one to be the acceptor and the other to be a dialer..
the dialer dials n the acceptor accepts the connection.
then the pc's form a 1-1 connection and data access can take place on both connections..
it's not *necessary* to have separate software cauz windows networking can manage most things...
It should work - from a technical point of view there isnt any problem. Unless Reliance has blocked it!!!
However you will need software to enable your "server" phone to answer the call of the "client". But thats freely available anyways.
