priya
Pl2303 Usb Serial Convertor +lg Lst250
I am running linux kerenel 2.4.22. I have the following problem
I use a USB to serial adapter to connect to my phone. The info tool on KDE recognizes my serial port as follows...
USB UHCI Root Hub (3)
|___PL 2303 Serial Port
The 'dmesg' output shows that the pl2303 drivers are loaded but my device attached to the serial port is not recognized. How do i make it visible to linux.
check which serial port is assigned to the USB controller...
did you install the same driver ld_pl2303_v0213.zip ..? this is the Prolific driver for USB to serial for Kernel 2.4 and above..
WBR
Surej
Usually no linux drivers are shipped with USB to serial cables..it's always better that you find the driver from the specific chip manufacturer
WBR
Surej
