Aniket Raje 0 Report post Posted January 10, 2006 To make a ringtone out of your MP3 or WAVE file, you need to convert it into a QCP file. Instructions for doing it are as follows. First, if you are not starting with a WAV file, you need to convert your file (probably a MP3 file) into a WAV file. Use Google and search for "mp3 to wav freeware" (or whatever type of file you are starting with). You can find several good programs this way. One nice program is dBpowerAMP Music Converter (U will get a 30 days trial version unless u know warez to find a full version ). Now you need to downsample the WAV file to make it smaller and so that PureVoice can convert it. Change it to 8 khz (8,000 hz), 16-bit sound, and mono. At this point, I strongly suggest using the Windows sound editor to make it about 30 seconds long or shorter. If you plan on using it as a ringer, you likely won't hear any more than 30 seconds of your song. By making it shorter now, you make the file a lot smaller. Now you need to use Qualcomm's PureVoice Converter (http://www.cdmatech.com/products/purevoice_download.jsp). Download and unzip it. The converter is a little DOS-based program. The easiest way to run it is to just drag your WAV file on top of the program, and it will automatically create a QCP file for you. Well u now have ur very own ringtone ready for use. The only thing left to do is to transfer it to ur phone. U can do this either via a data cable or by sending the ringtone as an MMS to ur phone (Hoping u know how to do that!! ). So there u have it ur very own truetone free of cost. Enjoy!! Share this post Link to post Share on other sites
tanveer 59 Report post Posted January 10, 2006 the final ringtone will be in qcp format right. I think only 6130 and 6000 support this format. Share this post Link to post Share on other sites
shashank 8 Report post Posted January 10, 2006 but will this work in all handsets or only the handsets that support mp3??? Share this post Link to post Share on other sites
Aniket Raje 0 Report post Posted January 10, 2006 but will this work in all handsets or only the handsets that support mp3??? MP3 is different from QCP format. Most cdma handsets do support QCP files. QCP ringtones work on 6130 and all other handsets which support QCP files. but will this work in all handsets or only the handsets that support mp3??? All my friends unfortunately have 6130 so there is no way for me to check if this works on other handsets. Although technically it should as most cdma handsets support QCP file format. Share this post Link to post Share on other sites
shashank 8 Report post Posted January 10, 2006 Can you please tell which will sup QCP formats.Will nokia 3105 support that? Share this post Link to post Share on other sites
Arun 795 Report post Posted January 10, 2006 The lastest handsets, LG RD 6230 and Nokia 6235 hansets support .qcp ringtones. Not every qualcomm based handsets support qcp though. Moving to Technical forum Share this post Link to post Share on other sites
rahulmalik_81 1 Report post Posted January 10, 2006 hi all. here is a tutorial which i found out while surfing to make a mp3 or wave ringtone from a mp3 file. You will have to get some sound editors i.e audacity,lame, and razrlame(lame gui) Audacity and razorlame can be found here http://audacity.sourceforge.net/download/windows and razorlame here http://www.dors.de/razorlame/download.php 1. Open the mp3 u want to make a ringtone in audacity 2.Select end of the song, and delete(I normally left 20-30 sec but it can be more(it's upto u)). 3.select about last 2 seconds of the file and put a "fade out" effect in effect menu. 4.export the final edition of file as wav(in file menu) 5.Now open razorlame use these settings : Bitrate should be set to 32 bit Mode should be mono and Lame option should show this -b 32 -m m 6.then add the exported wav file to razorlame and export it -> ringtone ready 7.now u can transfer the mp3 file to ur handset ive tried and tested this method and ive been able to upload mp3 ringtones to my nokia handset(3155) hopes everybody like it. Share this post Link to post Share on other sites
Aniket Raje 0 Report post Posted January 10, 2006 (edited) Can you please tell which will sup QCP formats.Will nokia 3105 support that? Nokia 3105 supports AMR format. I am not sure if it supports QCP format. U can download MP3 to AMR converter called Mobile ringtone converter from < Link Removed > for free. WARNING!!! Don't post Warez links next time! Edited January 11, 2006 by Vishal Gupta Share this post Link to post Share on other sites
WALKER 0 Report post Posted January 17, 2006 Aniket the site you told for downloading Qualcomm's PureVoice Converter (http://www.cdmatech.com/products/purevoice_download.jsp). in that the links from where we can download are not working can you please tell another link or send me the software. Thanks Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted January 17, 2006 Its working fine for me! neway the Direct link is here. Share this post Link to post Share on other sites
Aniket Raje 0 Report post Posted January 18, 2006 Aniket the site you told for downloading Qualcomm's PureVoice Converter (http://www.cdmatech.com/products/purevoice_download.jsp). in that the links from where we can download are not working can you please tell another link or send me the software. Thanks Sorry dude i tried uploading the software but it exceeds the allowed limit. If u still haven't got the software let me know. I'll email it to you. Adios Share this post Link to post Share on other sites
bellamkonda 0 Report post Posted January 20, 2006 (edited) Hey Ankite or Vishal, Please let me know whether my N191 supports QCP ringtone format... And how to use this QCP format to send as MMS .. Can any one let me know try uploading the same in www.mooload.com Thanks Sarath Edited January 20, 2006 by Chirag Share this post Link to post Share on other sites
basant_jp 0 Report post Posted March 13, 2006 The link to download Purevoice converter not working. Some one please send me the alternative link to download. cheers! Share this post Link to post Share on other sites
shashank 8 Report post Posted March 13, 2006 I think the same principle is used by tata for voice tunes in their brew.They charge Rs.14/each tone. Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted March 13, 2006 @basant_jp D/l from here... Share this post Link to post Share on other sites
KingofKalyan 0 Report post Posted March 13, 2006 @basant_jpD/l from here... Files are corrupted in that Vishal.. Not working :'( Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted March 13, 2006 OKie! I hv u/l ed the file here. ENJOY!!! Share this post Link to post Share on other sites
drali 6 Report post Posted March 14, 2006 can anyone give tutorial on PSM player (wav to midi). i m using nokia3125. which support midi. thanks! Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted March 14, 2006 Here u go buddy: CREATE CUSTOM RINGTONE FILE Share this post Link to post Share on other sites
Aniket Raje 0 Report post Posted March 22, 2006 You can send your ringtone creations as an mms wsing the reliance mms portal. After registering you can actually send mms like your regular e-mail. The portal<a HREF=http://bill.relianceinfo.com/webapp/portal/servlet/LoginServlet> link </a> is Share this post Link to post Share on other sites
KingofKalyan 0 Report post Posted March 22, 2006 You can send your ringtone creations as an mms wsing the reliance mms portal. After registering you can actually send mms like your regular e-mail. The portal<a HREF=http://bill.relianceinfo.com/webapp/portal/servlet/LoginServlet> link </a> is Are u sure its working... because they have stop it between this service Share this post Link to post Share on other sites
