shreepadabhat
Treo 650 Cdma
Hi All you RIM/CDMA Gurus. I have a Treo 650 Smartphone from the US which is unlocked CDMA (used to be on Sprint). Can this be activated over RIM using the GSK option? Or does Reliance not all ESNs that are not on their provisioning list?
I guess not unless the ESN is either re-provisioned to be on the RIM list, (or u fake a rim esn ... ) really not sure if u are gonna get it working around here ;)
Cheers
Ashok
If it has an RUIM slot,then it will definetly work with tataindicom as you said it is unlocked handset.
Hey ur phone is now active? if yes please help me to active the same
