Anilkumar 0 Report post Posted February 2, 2006 I bought a ZTE MC325 R connect card for Rs6500/ today with a post paid freedom plan. But unfortunately the card does not go into my Dell note book express card slot which is TYPE III MINI PCI card slot.The width of the slot is identical in the beginning but later there is a 22mm notch. (The double width card is 54mm x 74mm (has a 22mm notch). Essentailly Reliance info com at Ranipet was not having any Demo card so i had to buy the above. But they are not willing to take back the card or replace it with a matching Rconnect card otherwise a new mobile. Can any one of the members help me know the right procedure to be followed to get this card changed? Also is there any way to use the existing ZTE MC325 R connect card with express card slot which is TYPE III MINI PCI card slot using some adaptrers. Look forward to your help. Anilkumar.S 04172 241391 Share this post Link to post Share on other sites
supernova 47 Report post Posted February 2, 2006 i dont think reliance will buy back that card . what you can do is sell it to someone . but it will cost u 500 as tranfer charges + whatever amount he cuys from 6500 Share this post Link to post Share on other sites
