@ksh@T
Phone Switches Off...when Rworld Is On
guys from past few months i have been experiencing that whenever i open rworld my phone switches off....after a few minutes whn i am in operation in RWORLD is this some sort of hardware or software problem....
@akshat
Same problem here with my LG RD 5340. I think this is a software problem. I will go to the service centre and ask them to upgrade the software.
well will go to service center and then see that.....
I think its a software problem. Did you come accross the "memory access" denied problem also ?
I'm also facing the same problem with my LG 6130.
I've stopped using RWorld as of now.
And the problem of hanging in between is becoming consistent..
I had the similar problem before 2 weeks. But now I can access r-world without any problem.
@honesT
well never heard of that message...but when i plug my phone into power and accesss RWORLD the phone doesnt goes off....
@akshatdesijallad
I think that there's a problem with the hardware of your phone. Just go to the service centre and clear your doubts.
