researcher 0 Report post Posted February 9, 2006 Hi friends when our RIM receives a callers number then how can we pass this value through send keys function or some other combination of AT commands by serial cable? Share this post Link to post Share on other sites
ashoksoft 83 Report post Posted February 9, 2006 Let that question be a little more clear... is this what u mean ... when someone calls u, and u pick the call (AT(%)P) and then u want something like a caller id, so that instead of a username / password u can use the caller id as username ?? If that is the question, the only way that I could think of ... but this is not using any AT commands... what u will have to do is to use bitpim / gagin to get the vals from the phone dir on ur phonelog (considering u are using a RD2030) and at least this process can be automated using sendkeys (in VB). If u want a demo, I will try to make one after I come back from my party at Matheran ... going there tonight !! will be back by sunday night I guess ... for another party, (parents anniversary). btw if u want to dial ... AT+CDV=Number will work ATD / ATH is for a hangup. Cheers Ashok Share this post Link to post Share on other sites
researcher 0 Report post Posted February 9, 2006 Let that question be a little more clear... is this what u mean ... when someone calls u, and u pick the call (AT(%)P) and then u want something like a caller id, so that instead of a username / password u can use the caller id as username ?? If that is the question, the only way that I could think of ... but this is not using any AT commands... what u will have to do is to use bitpim / gagin to get the vals from the phone dir on ur phonelog (considering u are using a RD2030) and at least this process can be automated using sendkeys (in VB). If u want a demo, I will try to make one after I come back from my party at Matheran ... going there tonight !! will be back by sunday night I guess ... for another party, (parents anniversary). btw if u want to dial ... AT+CDV=Number will work ATD / ATH is for a hangup. Cheers Ashok Yes dear You have understood my question correctly. But where do I get bitpim? I will first try and then question. Taran Share this post Link to post Share on other sites
researcher 0 Report post Posted February 9, 2006 (edited) If that is the question, the only way that I could think of ... but this is not using any AT commands... what u will have to do is to use bitpim / gagin to get the vals from the phone dir on ur phonelog (considering u are using a RD2030) and at least this process can be automated using sendkeys (in VB). I just downloaded BitPim 0.8.07 but it does not support LG RD2030. Any other way out please? Taran Edited February 9, 2006 by Chirag Share this post Link to post Share on other sites
kams19 0 Report post Posted February 9, 2006 search thru the forum, i suppose some older version does support it.. Share this post Link to post Share on other sites
researcher 0 Report post Posted February 9, 2006 search thru the forum, i suppose some older version does support it.. Can you tell me which version, so that I can search and download the right stuff? I will be trying anyway just now. Thanks. Share this post Link to post Share on other sites
ashoksoft 83 Report post Posted February 9, 2006 Even the latest version supports RD2030 what u need to do is to choose the phone as LG VX-6000 and detect as normal in the options somewhere there is a show filesystem. which has to be activated. ANY UPDATES AFTER 12th coz I might be offline till then Cheers ashok Share this post Link to post Share on other sites
researcher 0 Report post Posted February 10, 2006 Even the latest version supports RD2030 what u need to do is to choose the phone as LG VX-6000 and detect as normalin the options somewhere there is a show filesystem. which has to be activated. ANY UPDATES AFTER 12th coz I might be offline till then Cheers ashok Did as advised with ver 0.8.07 but could not detect phone. Lets try after 12th Feb. Bye Share this post Link to post Share on other sites
ashoksoft 83 Report post Posted February 13, 2006 back now ... do u want a step by step of how it is to be done ? can do that tommorrow Cheers Ashok Share this post Link to post Share on other sites
researcher 0 Report post Posted February 13, 2006 back now ... do u want a step by step of how it is to be done ? can do that tommorrow Cheers Ashok Thanks. Ok.We will do it tonight after 8pm. Is it ok? Bye Taran Share this post Link to post Share on other sites
researcher 0 Report post Posted February 16, 2006 (edited) back now ... do u want a step by step of how it is to be done ? can do that tommorrow Cheers Ashok Thanks. Ok.We will do it tonight after 8pm. Is it ok? Bye Taran Dear Ashok When can we do a step by step test? Taran Edited February 16, 2006 by researcher Share this post Link to post Share on other sites
ashoksoft 83 Report post Posted February 17, 2006 Got offs on Sat / Sunday... so will try to contact u on one of the said days Cheers (PS : Please at least miss call me .. .so that I remember) Ashok Share this post Link to post Share on other sites
researcher 0 Report post Posted February 17, 2006 Got offs on Sat / Sunday... so will try to contact u on one of the said days Cheers (PS : Please at least miss call me .. .so that I remember) Ashok Thanks Ashok. When in late evening I am free I will call you. Bye Taran Share this post Link to post Share on other sites
