ajay_delhi 0 Report post Posted February 10, 2006 Hi ! I have got a new prepaid on a friend's old Lg-rd-2030 to use r-connect on my laptop. Since afternoon, I am trying to activate r-connect by dialling *412 but I get a busy tone instead of a long acceptance tone. And obviously,I dont a confirmation message after that. Please help. Regards Ajay Share this post Link to post Share on other sites
Chirag 5 Report post Posted February 10, 2006 R-Connect is preactivated on all connections, now. You dont need to manually do that! Jus make a dialer on your PC and get going! Read more on these forums for help on installing the R-Connect Dialer. Share this post Link to post Share on other sites
Honest 836 Report post Posted February 10, 2006 I agree with chirag. @ ajay install the software which came to you in the c.d. with the data cable and all your hurdles would be solved. Share this post Link to post Share on other sites
ajay_delhi 0 Report post Posted March 7, 2006 Today, I have bought a Nokia 6235 for R-conncect as I already had a DKU-2 and CA-53 (both compatibe). I connect the phone, drivers are preperly installed. (I have been using N70 and N3230 on the same cable). It dials #777 (visible even on phone screen) but error 678 comes that says "no answer". If I manually dial the number (#777) on the phone, it says "Pls check the number u have dialled". Pls help what to do. Regards Ajay Share this post Link to post Share on other sites
Arun 795 Report post Posted March 11, 2006 Today, I have bought a Nokia 6235 for R-conncect as I already had a DKU-2 and CA-53 (both compatibe). I connect the phone, drivers are preperly installed. (I have been using N70 and N3230 on the same cable).It dials #777 (visible even on phone screen) but error 678 comes that says "no answer". Are you sure the phone is not in lock mode ? Have you unlocked the phone by entering the secret code and disabling it, before dialling ? Share this post Link to post Share on other sites
KingofKalyan 0 Report post Posted March 11, 2006 Today, I have bought a Nokia 6235 for R-conncect as I already had a DKU-2 and CA-53 (both compatibe). I connect the phone, drivers are preperly installed. (I have been using N70 and N3230 on the same cable).It dials #777 (visible even on phone screen) but error 678 comes that says "no answer". If I manually dial the number (#777) on the phone, it says "Pls check the number u have dialled". Pls help what to do. Regards Ajay No need to do all this stuffs for Nokia 6235... Just Install the Rconnect to ur PC or laptop and connect it with ur handset and Enjoy the R connect.. Just let us know the error message and the no.. IF ur getting any probs.. Share this post Link to post Share on other sites
Utsav 0 Report post Posted March 11, 2006 Pls check if your phone is properly detected and is responding to the dialer of your PC. Share this post Link to post Share on other sites
ajay_delhi 0 Report post Posted March 12, 2006 (edited) Thanx a lot guys for your reply. I spent the whole day I bought Nokia 6235 (7th March) and as I mentioned connection was OK. I could trnasfer MP3 and all. I tried all that on a Desktop and a Laptop. And there was some problem in the customer care lines. By evening, I managed to talk (after many tries) to someone who was good at r-connect. He understood the whole thing. And it was just an extra intitilization command (AT+CRM=1;+CSO=33) that was required. In fact even now, since I am using a Nokia N70, N3230 and Nokia 6230, I keep on switing mobile to the computer so whenever I connect Nokia 6235 after any other model, it gives same problem. Then I give this intitilization string. Then it works perfectly. I don't even have to go to Nokia PC Suite and uncheck USB DKU-2cable connection in "manage connection" as mentioned by someone in another forum. I hope, it will help others as well. Thanx Ajay. Edited March 12, 2006 by ajay_delhi Share this post Link to post Share on other sites
KingofKalyan 0 Report post Posted March 12, 2006 . And there was some problem in the customer care lines. By eveing, I managed to talk (after many tries) to someone who was good at r-connect. He understood the whole thing. And it was just an extra intitilization command (AT+CRM=1;+CSO=33) that was required. Thats good to know there are some GOOD agents in Reliance CC at r connect as well.. who understand the probs.. When i got stuk up with my kyocera.. No one from Reliance was able to help me out.. Share this post Link to post Share on other sites
k3t 0 Report post Posted March 15, 2006 Thanx a lot guys for your reply.I spent the whole day I bought Nokia 6235 (7th March) and as I mentioned connection was OK. I could trnasfer MP3 and all. I tried all that on a Desktop and a Laptop. And there was some problem in the customer care lines. By evening, I managed to talk (after many tries) to someone who was good at r-connect. He understood the whole thing. And it was just an extra intitilization command (AT+CRM=1;+CSO=33) that was required. In fact even now, since I am using a Nokia N70, N3230 and Nokia 6230, I keep on switing mobile to the computer so whenever I connect Nokia 6235 after any other model, it gives same problem. Then I give this intitilization string. Then it works perfectly. I don't even have to go to Nokia PC Suite and uncheck USB DKU-2cable connection in "manage connection" as mentioned by someone in another forum. I hope, it will help others as well. Thanx Ajay. HI ajay i have nk2280 & ca 42 cable though i can connect to nk pc suite i cant connect to rcoonect the guys at cc have been constantly telling that "our system is under maintenance call later" since a week i am frustrated & thinking of switching back to tata indicom because i used to install tata dialer on any os in 2 mins in case of XP i dont even have to restart pc it was so easy i switched to reliance cause that rim gives more speed ie 144 KBPS whereas tata offered average 88 kbps But rim is getting on my nerves i installed modem driver on nokia website BUt during net connection setup it asks for number to dial i dont know which number to provide i used *777 but it says "error 678:the remote comp didnt respond" i will be very thankfull to some one who can help me out tell me how to insert that string os:XP pro thnx Share this post Link to post Share on other sites
KingofKalyan 0 Report post Posted March 15, 2006 "i will be very thankfull to some one who can help me out tell me how to insert that string os:XP pro thnx I dont understand one thing why do u guys dont contact Customer care of Reliance by email... Or just directly shoot a mail to chairman with ur problems.. Instead of thinking to switch with other service providers.... Share this post Link to post Share on other sites
k3t 0 Report post Posted March 16, 2006 freind the guys at cc always tell me what i already know they dont know much & email i dont think they even care to read i sent it a week ago no callback who knows the chairmans mail address what isn the guaranty he will read it i was very happy with tata indicom but they send long bills too easy to install tata indicom installing rconnect has become kinda adventure looks like rim isnt interested in dial-up customers its been 2 weeks since i bought the cable and i have given up all hopes that i could ever connect with rim i really loved my rim in past but now i hate it thnx :'( Share this post Link to post Share on other sites
ajay_delhi 0 Report post Posted March 17, 2006 Did you try extra intitilization command (AT+CRM=1;+CSO=33) in Modem Properties -> Advance Tab ? freind the guys at cc always tell me what i already know they dont know much & email i dont think they even care to read i sent it a week ago no callback who knows the chairmans mail address what isn the guaranty he will read it i was very happy with tata indicom but they send long bills too easy to install tata indicom installing rconnect has become kinda adventure looks like rim isnt interested in dial-up customers its been 2 weeks since i bought the cable and i have given up all hopes that i could ever connect with rim i really loved my rim in past but now i hate it thnx :'( Share this post Link to post Share on other sites
