unnikrishnan.vg
Lifetime Voucher & Rconnect Charges
yes.... lifetime is for the incoming... and nothing to do with rconnect... charges still apply as usual..
Cheers
ashok
Cheers
ashok
Thanks. I will recharge tomorrow itself. I have used the 18000 SMS Pack. Will I be able to use that after recharging?
You mean you will recharge with the 995 voucher for lifetime incoming ? Yes, you can use SMS mania card along with prepaid lifetime offer. Its only for the postpaid lifetime offer that you cannot bundle with on-net SMS pack or RIM2RIM pack.
@unnikrishnan.vg
You will be charged as per the default plan to use Rconnect.
Guest
