solanky 0 Report post Posted March 1, 2006 Hi, I have a strange problem. In one of our branch office there are three computers connected thru LAN. The IPS are in 192.168.0.x series. All was well but when we installed Rconnect on one computer and connect to internet the computer was not accesable to other computers. After disconnecting to rconnect the problem still persist. What problem I think is that Rconnect assignes a new IP Address so it has been detached from LAN. Have anyone else has faced this problem. If yes then please reply. Thanks. Share this post Link to post Share on other sites
Ashokjp 15 Report post Posted March 2, 2006 There should not be any problem with lan. unless you have a lan ip assigned on same subnet as of rconnect public ips. Share this post Link to post Share on other sites
Arun 795 Report post Posted March 2, 2006 wierd, but R-Connect doesnt change the TCP/IP properties of your Network Card. Check what is mentioned in: 'ipconfig /all' (run in DOS) to see whether the settings are correct. Share this post Link to post Share on other sites
solanky 0 Report post Posted March 2, 2006 I have checked ipconfig and the ipaddress is coming 0.0.0.0 while it is 192.168.0.1. It means it is changing the TCP IP properties. Share this post Link to post Share on other sites
dacodecz 0 Report post Posted March 2, 2006 Hi,I have a strange problem. In one of our branch office there are three computers connected thru LAN. The IPS are in 192.168.0.x series. All was well but when we installed Rconnect on one computer and connect to internet the computer was not accesable to other computers. After disconnecting to rconnect the problem still persist. What problem I think is that Rconnect assignes a new IP Address so it has been detached from LAN. Have anyone else has faced this problem. If yes then please reply. Thanks. Hi, Well check the IP assigned to your ethernet card in the settings dialogbox. And also check how your routing table looks like, are you using DHCP thingy ? I have checked ipconfig and the ipaddress is coming 0.0.0.0 while it is 192.168.0.1. It means it is changing the TCP IP properties. HI 0.0.0.0 is special case of generic IP addr assignment, 0.0.0.0 corresponds to INADDR_ANY means this adress is bind to all interfaces as target but its sementics is for packets routing only. Check are you using DHCP thingy ? Share this post Link to post Share on other sites
ramavijay1853 0 Report post Posted March 16, 2006 Hi,I have a strange problem. In one of our branch office there are three computers connected thru LAN. The IPS are in 192.168.0.x series. All was well but when we installed Rconnect on one computer and connect to internet the computer was not accesable to other computers. After disconnecting to rconnect the problem still persist. What problem I think is that Rconnect assignes a new IP Address so it has been detached from LAN. Have anyone else has faced this problem. If yes then please reply. Thanks. Format Total Disk After that install Winroutelite Lan Software (http://www.downlinx.com/proghtml/350/35075.htm) Then the problems will resolve Rama Vijay Hardwarer Share this post Link to post Share on other sites
solanky 0 Report post Posted March 16, 2006 Format Total DiskAfter that install Winroutelite Lan Software (http://www.downlinx.com/proghtml/350/35075.htm) Then the problems will resolve Thanks but can you please tell in detail about the solution??? Share this post Link to post Share on other sites
tackphoton 0 Report post Posted September 11, 2008 Ah! I had this same problem for the last two days.... just fixed it. \m/ First of all use static IPs only in both connections, 1. Open your LAN TCP/IP settings properties 2. Go to WINS tab 3. Choose Enable NETBIOS option. This shud help you make static IP association possible in LAN when a dial-up is present. Sorry for typing this info in a hurry.. will repost if not clear Cheers.. Share this post Link to post Share on other sites
