MVP
Content-type Header
I use text based browser most of the time to view rimweb forum.
From today ,I am getting the error message
"Content type is .Do you want to save or display this file?" and it displays the source html code when viewed in text browsers like lynx,links etc.
This is the response header got from rimweb.
HTTP Response Header
Name Value Delim
HTTP Status Code: HTTP/1.1 200 OK
Date: Fri, 03 Mar 2006 05:53:12 GMT CRLF
Server: Apache/1.3.34 (Unix) mod_jk/1.2.14 mod_fastcgi/2.4.2 mod_auth_passthrough/1.8 mod_log_bytes/1.2 mod_bwlimited/1.4 FrontPage/5.0.2.2635 mod_ssl/2.8.25 OpenSSL/0.9.7a CRLF
Connection: close CRLF
Transfer-Encoding: chunked CRLF
Content-Type: CRLF
The content type should have been
Content-Type: text/html
This works in normal browsers like IE,Mozilla etc .The problem is only with text based browsers
Cheers
Mathew
May i know what you mean by text based browser ?
an example plz ?
Name Value Delim
Content-Type: CRLF
Cheers
Mathew
A workaround would be to use the following option with [e]links
elinks -force-html http://rimweb.in
and it works perfectly.
If you have access to lynx then you don't even have to use any option.
Try accessing now.
Problem still persist.
chandaal@rudra:$ lynx --dump -head http://rimweb.in
HTTP/1.1 200 OK
Date: Fri, 03 Mar 2006 12:31:07 GMT
OpenSSL/0.9.7a
Connection: close
Content-Type:
Tried the -force-html option with links,not working for me.
Lynx works but lynx doesn't format tables.
How about
elinks -default-mime-type text/html http://www.rimweb.in
can you post the output of elinks -version ?
We did have a change in server settings from about 48 hours back. I guess that has something to do with your problem. We are checking it and hope to fix the problem as soon as possible.
5 second back i got this error
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, webmaster@rimweb.in and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/1.3.34 Server at www.rimweb.in Port 80
Thanks for reporting it cracker. We may still have a few dowtimes as Apache will be restarted for checking the changed settings.
