drali 6 Report post Posted March 9, 2006 lost some valuable data by mistake(shift+delete). how to get it back? thanx! Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted March 9, 2006 There r many Data recovery s/w available on net, u can use ne of them! Some good s/w r as follows: Recover My Files R-Studio PC Inspector Share this post Link to post Share on other sites
nilay 0 Report post Posted March 9, 2006 (edited) drali2 said: lost some valuable data by mistake(shift+delete).how to get it back? thanx! easy reover and other so maney utiitys. but r-studio is bast Edited March 9, 2006 by nilay Share this post Link to post Share on other sites
Jiss Abraham 0 Report post Posted March 9, 2006 most of these tools wont support all the file formats. so b careful before deleting Share this post Link to post Share on other sites
manishag 17 Report post Posted March 9, 2006 some times these softwares don't work if you overwrite so its better not to save the new files in that drive before recovring all the files Share this post Link to post Share on other sites
shali 0 Report post Posted March 9, 2006 These softwares are not freely available on the net, i mean they need some cracking. One more thing its not 100% guaranteed. the file recovered can get corrupted even if there is no activity on the drive. Share this post Link to post Share on other sites
cracker 0 Report post Posted March 9, 2006 here is something i found in my group Quote From: Flo Hey, there's many ways to recover that folder.. here's one that is sure to work: download & unzip & run this app --> http://www.frenchgourmetmarket.com/f4fs301a.zip Once you got it running, select the Search Mode: 'Long Search' select the disk drive that has your documents in Look in: (either Disk 0, Disk 1, or Disk 2, ...) select Search for: All Files (*) and Recover to: browse to your new My Documents folder for example then hit the fat Search button and wait... once the search is complete, click the 'Tree View' button at the top of the app.. and browse through the search results for your lost documents.. tick whatever you want to recover and click the Recover button.. simple! good luck. free ware Share this post Link to post Share on other sites
KumaarShah 143 Report post Posted March 10, 2006 Vishal Gupta said: There r many Data recovery s/w available on net, u can use ne of them!Some good s/w r as follows: Recover My Files R-Studio PC Inspector Hello, Do you know of any utility which can recover data from Zipped files with the password lost or forgotten? Thanks in advance. Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted March 10, 2006 There r many s/w available for ZIP Password recovery! http://www.pcworld.com/downloads/file_desc...fid,6153,00.asp http://www.picozip.com/prt/index.html http://www.zip-backup.com/zippassword/ http://www.zipcure.com/ Share this post Link to post Share on other sites
KumaarShah 143 Report post Posted March 10, 2006 Thanks a ton, mate for the instant help. Share this post Link to post Share on other sites
drali 6 Report post Posted March 11, 2006 thank you all for d timely help. cud any one tell me where this data goes after deleting it from d recycle bin? thanks! Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted March 11, 2006 Following topic will help u in this matter: Can You Ever Really Erase A Computer File? Share this post Link to post Share on other sites
drali 6 Report post Posted March 11, 2006 Vishal Gupta said: Following topic will help u in this matter:Can You Ever Really Erase A Computer File? thank u vishal.its really a gr8 information for a non techie man like me. Share this post Link to post Share on other sites
Utsav 0 Report post Posted March 11, 2006 Ever tried Unerase.exe from Norton? Share this post Link to post Share on other sites
Gauravsinghal 11 Report post Posted February 1, 2008 How to recover a deleted RAR file? As s/w i used like get my data back and many others are not to recover the deleted RAR file. Help me please. Share this post Link to post Share on other sites
Honest 836 Report post Posted February 1, 2008 ^^^ @gaurav My dear friend, try some googling. Their are many free softwares available on the net for your purpose. I'm sure you will get the one easily. Regards. Share this post Link to post Share on other sites
universea8 0 Report post Posted February 17, 2008 yes wen can recover deleted data by using recovery software and it available in net. < Spam Removed - Vishal Gupta > Share this post Link to post Share on other sites
chandannasta 4 Report post Posted February 18, 2008 What is the difference between file shredder and recycle bin. Can files also be recovered if shredded through file shredder? Share this post Link to post Share on other sites
Honest 836 Report post Posted February 18, 2008 ^^^ @chandan nasta My dear friend, you can't recover a file which has been shredded from your computer. Only top most labs which work as computer forensic can do the trick. Regards. Share this post Link to post Share on other sites
