aspark 0 Report post Posted April 21, 2004 Dear Friends, I am using XP and some how configured 2280 to connect to internet. I get an error message of "Enhancement Not Supported" on my handset after a minute of connecting and then computer can't recieve any data from the modem(handset). I need to switch off and switch on mobile before reconnecting. Any help on solving this is highly appreciated Arunkumar Share this post Link to post Share on other sites
Greens 21 Report post Posted April 21, 2004 Better contact Nokia authorised service centre in your city. Share this post Link to post Share on other sites
e_rajeev 0 Report post Posted August 30, 2004 Hey I too have the same problem. And the guys at *333 does'nt have a clue And what more they reduced more than Rs 300 from my prepaid charge too. Now my worry is my money !! Rajeev E Share this post Link to post Share on other sites
Utsav 0 Report post Posted November 10, 2004 R u sure Nokia 2280 is RConnect compatible? Share this post Link to post Share on other sites
kshah 452 Report post Posted November 11, 2004 Nokia 2280 is R connact compatible. There are few issues need to be kept in mind: 1. Data cable. If data cable (aftermarket) are not using original DKU 5 drivers then possibly it does not work. Prolific USB serial converter driver works well. 2. Install modem using this driver Nokia Mobile Phones CDMA 1xRTT Data/Fax, V1.0 3. When data cable is connected, enhancement not supported displayed in each phone. When it is displayed it does not work with some of PC sync softwares but R connect does work. 4. When you disconnect, reboot phone before reconnecting. Some times system also need reboot. 5. Install USB drivers first, then attach cable, let system install cable drivers, then connect handset and install modem. Attaching .inf file, which works on my XP system. Share this post Link to post Share on other sites
kshah 452 Report post Posted November 11, 2004 sorry unable to attach inf file. Share this post Link to post Share on other sites
Code 0 Report post Posted November 12, 2004 sorry unable to attach inf file. 18749[/snapback] U can either zip it or post the contents of the file as it is a plain text file. Share this post Link to post Share on other sites
stranger 0 Report post Posted November 16, 2004 Incase here is prolific URL: http://tech.prolific.com.tw/visitor/v_welcome.asp Share this post Link to post Share on other sites
