virtual 0 Report post Posted April 15, 2006 I can not install any application in my 6255 model Share this post Link to post Share on other sites
ashoksoft 83 Report post Posted April 15, 2006 can that post be a little more elaborate ? what did u do, how did u try to connect the phone, and how are u trying to do the install? If ur posts are elaborate, and descriptive, it becomes easier to assist you... just a one liner like "My friend slapped me" will not yield results, as others will not be able to understand the underlying cause... please respond back with a more descriptive post, and we are sure someone will assist you! cheers Ashok Share this post Link to post Share on other sites
snappy 0 Report post Posted April 19, 2006 ashoksoft said: can that post be a little more elaborate ? what did u do, how did u try to connect the phone, and how are u trying to do the install?If ur posts are elaborate, and descriptive, it becomes easier to assist you... just a one liner like "My friend slapped me" will not yield results, as others will not be able to understand the underlying cause... please respond back with a more descriptive post, and we are sure someone will assist you! cheers Ashok hi i just bought a nokia 6255 reliance i can not install any applications on my phone no jar or jad files work they are displayed with a question mark an when i try installing it using nokia pc suite it says thhere is no compatible phone selected ..... an when i try mobimb it installs software but the software is not displayed i don know what wrong i went to nokia care it says tht reliance has blocked iyts features .... so cant help it !!!!!!!!!1 Share this post Link to post Share on other sites
