Hareesh 0 Report post Posted April 28, 2006 Hi, I'm facing a peculiar problem. I'm being able to connect to internet using my LG5130 (serial cable). But the data transfer rate is always ZERO bytes. Have anyone of you seen this before? Are there any possible solutions for this? I've already done the below: 1. Checked the signal strength and it looks decent. 2. Uninstalled the modem / network connection and Driver and re-installed everything once again. 3. Got my RConnect re-activated through Reliance Customer Care. Unfortunately none of these have helped in any respect. Any help would be highly appreciated. regards, Hareesh B'lore. Share this post Link to post Share on other sites
Nirvana 4 Report post Posted May 5, 2006 Hareesh, not sure if you are still having the problem, anyway... have you checked for any spywares in your PC ? Or is a firewall configured incorrectly ? This issue mostly occurs due to some software conflict in your computer. Other chance is network problem which occurs rarely only these days. Share this post Link to post Share on other sites
Hareesh 0 Report post Posted May 9, 2006 Hello Nirvana, IT WORKS !!!! Thanks a tonne for that valuable suggestion. The firewall configuration in my pc had been tampered and this was causing the problem. Once the same was corrected, am being able to getting decent speed to connect through Rconnect. Hence my problem can be summarised as "Incorrect configuration of Firewall was blocking the data transfer". Thanks once again, Hareesh Share this post Link to post Share on other sites
amitstg 0 Report post Posted May 9, 2006 thanks to nirvana ! Share this post Link to post Share on other sites
jag82 0 Report post Posted May 19, 2006 Hello Nirvana,IT WORKS !!!! Thanks a tonne for that valuable suggestion. The firewall configuration in my pc had been tampered and this was causing the problem. Once the same was corrected, am being able to getting decent speed to connect through Rconnect. Hence my problem can be summarised as "Incorrect configuration of Firewall was blocking the data transfer". Thanks once again, Hareesh Hi Im also getting similar problem with my nokia 2112 phone with dku-5 datacable.It gets connected but im not able to surf net as no data transfer takes place.Can you please elaborate how you solved this problem/what configuration you used for ur firewall Thanks Share this post Link to post Share on other sites
rushik 0 Report post Posted May 19, 2006 Hi,I'm facing a peculiar problem. I'm being able to connect to internet using my LG5130 (serial cable). But the data transfer rate is always ZERO bytes. Have anyone of you seen this before? Are there any possible solutions for this? I've already done the below: 1. Checked the signal strength and it looks decent. 2. Uninstalled the modem / network connection and Driver and re-installed everything once again. 3. Got my RConnect re-activated through Reliance Customer Care. Unfortunately none of these have helped in any respect. Any help would be highly appreciated. regards, Hareesh B'lore. Hey Hareesh, I am facing the same kind of problem with my RD5130, when I connect using my laptop having XP, I some huge number in sending data but the receiving data is very very less, thus after searching for some time it gives me 'Cannot Display Page', Is this something with firewall? Please guide me, Thanks Rushik. Share this post Link to post Share on other sites
Hareesh 0 Report post Posted May 22, 2006 Rushik, Check if you have installed any firewall s/w in your machine. I had sygate personal firewall in my pc and some corruption on this was causing the problem for me. Uninstalling and Re-installing the same fixed the issue for me. regards, Haresh Share this post Link to post Share on other sites
