sumitbit
Nokia 6255 Internet Connection Setup Problem
I am using NOKIA 6255 CDMA reliance handset and IVT-BlueSoleil Bluetooth adapter to connect to internet.
When i try to connect using my mobile which i hv configured as DUN modem on port13, i try doing it using 2 options:
1) Using Bluesoleil application option -> connect using Dial-up networking ,
there it says - Starting RAS failed.
2) when i try to make a new netwok connection from my Windows XP SP2 add connection option, the connect to internet manually option is shown as disabled in the internet connection wizard.
Can u help on this?
Can u help on this?
HI Mahinder,
Thnx for the concern, but i can't find any help on these locations.
You may note that my problem may be specific to IVT Bluesoleil Bluetooth dongle or some system setting which i m not able to solve.
I searched RIM forum thoroughly but cant find any stuff on this in particular.
i u hv any idea abt this, pls suggest
Regds,
Sumit
I am having similar kind of problem. I am trying to connect to internet through BlueSoleil dongle and Nokia 6255. But neither of devices is recognizing each other. I am unable to pair both of them. I am trying to use bluetooth connector on my Sony Vaio Laptop which has Vista installed.
All my options is Bluesoleil s/w are deactivated. Only configurations and my device is activated.
Please help me in this regard.
