Vishal Gupta 4 Report post Posted August 17, 2004 Guys! I got success in detecting LG LSP340E with Bitpim. Now I can access its file system. I am attaching a screenshot of it. 1 Share this post Link to post Share on other sites
Code 0 Report post Posted August 18, 2004 Nice work vishal but as expected there is no ringtone directory And it's doubtful if the phone supports custom ringtones. Considering the fact that the directory tree is otherwise similar to LG mobiles U can try creating a directory with files similar to them. Create directory called: locsound Upload files : mhlsnd1 mhlsndh1 (get these from some RIM LG user) But note that there are a lot of hurdles: 1.$USER_DIRS will not have the entry for locsound directory. 2. We even don't know if there is support in the phone for recognizing these custom stuff. 3. You may even screw up ur phone by doing above (So try at your on risk) Share this post Link to post Share on other sites
sklm 0 Report post Posted August 18, 2004 Hi Vishal, How you accessed the file system of FWP. As far as I know that I provided the file LGKDP4_8.exe and the file connects the FWP at 38,000 bps and through this connection I was unable to use Bitpim. So, how you accessed the FWP through Bitpim? Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted August 18, 2004 Guys! Now I tell u how i did it? Whenever i tried to detect FWP with bitpim, it always gave following error: "The phone is not responding while transitioning mode from none to brew." So an idea came in my mind to change phone mode with the help of uniCDMA and then again try with bitpim. So i convert phone into DM mode with the help of uniCDMA and then tried with bitpim again. and SUCCESS!!! So the steps to read file system of FWP with the help of bitpim are: 1. First open LGKDP to detect FWP. 2. Now close it and open uniCDMA and click on HF->DM button. 3. Now close uniCDMA and open bitpim, select phone type to anyone because i tried almost every type and all worked, now expand file system. Now u can successfully browse through file system. Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted August 18, 2004 In FWP file system there are some useful files that contain certain useful information. I am telling u name of such files: /->nvm->nvm->nvm_0001 ::-> I think this file contains Phone book of FWP. I found name of persons in this file that i've stored in my phone. /->nvm->nvm->nvm_0002 ::-> This file is very useful. U can find the 4-digit security lock code here in 8th line and 6-digit Field test lock code (required to enter in field test mode after pressing <Menu>+0 ) in 9th line. Thats it. I found nothing else important in FWP file system. Share this post Link to post Share on other sites
sklm 0 Report post Posted August 18, 2004 Hi Vishal, Have you seen that if the FWP is locked then the LGKDP can't connect? So, if anybody locks the FWP and want to unlock then how to get that if he/she forgets the code? Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted August 18, 2004 Have you seen that if the FWP is locked then the LGKDP can't connect?So, if anybody locks the FWP and want to unlock then how to get that if he/she forgets the code? I think u didnt read my following post: http://www.rimweb.com/forums/index.php?showtopic=1560 use 6278 ( master code ) as four digit lock code. This code will definitely work whether u specified any other code as security code. Share this post Link to post Share on other sites
Beetle 0 Report post Posted August 18, 2004 Interesting find! So.. You used Bitpim to find the field test code in nvm directory. Wanted to try it myself, never got hold of the phone. Share this post Link to post Share on other sites
webmaster1963 0 Report post Posted October 5, 2004 anybody know how to attach a parallel phone to fwp like fwt Share this post Link to post Share on other sites
Utsav 0 Report post Posted October 5, 2004 I believe u can't. Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted October 5, 2004 anybody know how to attach a parallel phone to fwp like fwt No Way!!!! Share this post Link to post Share on other sites
t9en 0 Report post Posted October 7, 2004 can u connect Parllel to your mobile?? NOWAY.... like that you can not connect parlel to FWP also... Share this post Link to post Share on other sites
Ashokjp 15 Report post Posted December 24, 2004 Bitpim doesnt detect To do that i tried uniCDMA as per vishal's post. But uniCDMA doesnot detect my phone... Any ideas ? Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted December 24, 2004 Bitpim doesnt detectTo do that i tried uniCDMA as per vishal's post. But uniCDMA doesnot detect my phone... Any ideas ? First open LGKDP and change port to COM1 from COM2 (if ur phone is connected to COM1), when it shows "Phone connected" in its address bar. Then close it and open UniCDMA, now it'll surely detect ur FWP! Share this post Link to post Share on other sites
Ashokjp 15 Report post Posted January 8, 2005 my phone was first detected as com3 as it was connected using USB.. Then i changed ports and made it COM2. I tried with LGKDP and changed its port to COM2.. It dint work... Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted January 8, 2005 I think LGKDP works only on Serial cables and not on USB cables? Try using Serial cable! Share this post Link to post Share on other sites
Ashokjp 15 Report post Posted January 9, 2005 I guess the data cable for LG i Phone is normal usb cable.. I had one such so i tried.. Nyways thnx for the info Share this post Link to post Share on other sites
vietcdma 0 Report post Posted January 15, 2005 I tried sucessfully with UniCDMA (DM Mode) but I still received "The phone is not responding while transitioning mode from none" from Bitpim.. What's wrong? Share this post Link to post Share on other sites
Arun 795 Report post Posted January 16, 2005 Try accessing using BitPim first, and then try uniCDMA (after closing) Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted January 16, 2005 I tried sucessfully with UniCDMA (DM Mode) but I still received "The phone is not responding while transitioning mode from none" from Bitpim.. What's wrong? Which set r u talking about? Is it FWP? If yes, then first open LGKDP then close it & open UniCDMA and click on HF -> DM button and then open bitpim. Now it'll surely work! Share this post Link to post Share on other sites
imvikky 0 Report post Posted January 17, 2005 I tried sucessfully with UniCDMA (DM Mode) but I still received "The phone is not responding while transitioning mode from none" from Bitpim.. What's wrong? Which set r u talking about? Is it FWP? If yes, then first open LGKDP then close it & open UniCDMA and click on HF -> DM button and then open bitpim. Now it'll surely work! 24467[/snapback] Vishal Is the same procedure aapplicable to RD2030 mobile too I have the same problem but reading thru all the posts n trying also didn't help me......... Everybody seems to be using this sofware so aaram se but I have no sucess.... Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted January 17, 2005 For RD2030, d/l the latest version of bitpim and open it, it'll surely detect ur phone. and if not, then open Hyper Terminal (In accessories -> Communications) and select ur phone installed as modem) and in terminal type AT$QCDMG, now close it and open bitpim. Share this post Link to post Share on other sites
imvikky 0 Report post Posted January 19, 2005 I tried doing that too i.e. I downloaded Bitpim.7.24 from sourceforge dated 06 Jan 04 but it did not detect my LG RD2030 then I loaded the software on a machine with Win 2K and no R connect or PC sync installed first it gave error phone did'nt respond while changing from none to brew then I loaded LGKDP and UniCDMA and tried to put phone on DM mode then tried again now the phone says exception n unexpected exception has occurred. Please see the help for details on what to do. Traceback (most recent call last): File "gui.pyo", line 152, in run File "gui.pyo", line 92, in __call__ File "gui.pyo", line 1148, in getdata File "gui.pyo", line 1142, in getfundamentals File "com_lgvx4400.pyo", line 87, in getfundamentals File "com_brew.pyo", line 238, in getfilecontents File "com_brew.pyo", line 441, in sendbrewcommand BrewNoSuchFileException: No such file Variables by last 8 frames, innermost last Frame __bootstrap in threading.pyo at line 436 self = <WorkerThread(BitPim helper, started daemon)> Frame run in gui.pyo at line 145 e = <com_brew.BrewNoSuchFileException instance at 0x02164918> res = None self = <WorkerThread(BitPim helper, started daemon)> item = (<gui.Request instance at 0x0214A940>, <gui.Callback instance at 0x021648A0>) call = <gui.Request instance at 0x0214A940> ex = <com_brew.BrewNoSuchFileException instance at 0x02164918> resultcb = <gui.Callback instance at 0x021648A0> first = 0 Frame __call__ in gui.pyo at line 92 self = <gui.Request instance at 0x0214A940> args = () d = Keys [] {} kwargs = Keys [] {} Frame getdata in gui.pyo at line 1148 self = <WorkerThread(BitPim helper, started daemon)> req = <guiwidgets.GetPhoneDialog; proxy of C++ wxDialog instance at _0006f401_p_wxDial todo = [(<bound method WorkerThread.rebootcheck of <WorkerThread(BitPim helper, started Frame getfundamentals in gui.pyo at line 1142 self = <WorkerThread(BitPim helper, started daemon)> results = Keys ['uniqueserial'] {'uniqueserial': '5f24d7134d06b1992b47cf86051598304f76e5c0'} Frame getfundamentals in com_lgvx4400.pyo at line 87 self = <com_lgvx4400.Phone instance at 0x02164A08> results = Keys ['uniqueserial'] {'uniqueserial': '5f24d7134d06b1992b47cf86051598304f76e5c0'} Frame getfilecontents in com_brew.pyo at line 238 self = <com_lgvx4400.Phone instance at 0x02164A08> req = <p_brew.readfilerequest object at 0x02162BD0> start = 1106135259.312 file = 'pim/pbgroup.dat' data = <cStringIO.StringO object at 0x02154CC0> desc = 'Reading pim/pbgroup.dat' Frame sendbrewcommand in com_brew.pyo at line 441 responseclass = <class 'p_brew.readfileresponse'> origdata = 'Y\x04\x06g\xdb~' d = 0 err = 6 buffer = <prototypes.buffer instance at 0x02164828> request = <p_brew.readfilerequest object at 0x02162BD0> callsetmode = True firsttwo = 'Y\x04' crc = 'g\xdb' data = 'Y\x04\x06' self = <com_lgvx4400.Phone instance at 0x02164A08> I can't make out much of it can you help me what do I do reading your last reply I tried to contact the phone using hyperterminal on giving command ate1 it replies OK but on giving command AT$QDCMG it says ERROR anyother suggestion Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted January 19, 2005 on giving command AT$QDCMG it says ERROR Its AT$QCDMG and not AT$QDCMG. So pls try the right command! Share this post Link to post Share on other sites
Ashokjp 15 Report post Posted January 20, 2005 Hey imvikky, if its difficult for you to work with at$.. command Though it works in the latest version.. Anyways use Bitpim 0.62.. It will surely load the filesys. Share this post Link to post Share on other sites
