schumi 0 Report post Posted June 17, 2006 I have purchased a New LG 5340 Handset from a dealer.But I feel the handset was used earlier.Hence I want to check with the RSN number of the handset whether the handset has been activated earlier or no.Also I have purchased a Prepaid GSK from Webworld but the number is not getting activated on the handset.I get the error message "Your phone cannot be activated,please contact Reliance".But the webworld had informed me that the Number has been activated from their end and I just need to dial *228 followed by the 9 digit pin number.So does anyone know the way,how I can find this out Please help Share this post Link to post Share on other sites
hondaactiva 0 Report post Posted December 4, 2006 I have purchased a New LG 5340 Handset from a dealer.But I feel the handset was used earlier.Hence I want to check with the RSN number of the handset whether the handset has been activated earlier or no.Also I have purchased a Prepaid GSK from Webworld but the number is not getting activated on the handset.I get the error message "Your phone cannot be activated,please contact Reliance".But the webworld had informed me that the Number has been activated from their end and I just need to dial *228 followed by the 9 digit pin number.So does anyone know the way,how I can find this out Please help ************************************ just type ODR and any lg rsn no. and get handset details for example ODR RLGHS(and rsn no.) and sms to 3738 and u will get 2 sms frm 3738 and 2811 ************************************** Share this post Link to post Share on other sites
hasanfa 0 Report post Posted August 24, 2008 I have purchased a New LG 5340 Handset from a dealer.But I feel the handset was used earlier.Hence I want to check with the RSN number of the handset whether the handset has been activated earlier or no.Also I have purchased a Prepaid GSK from Webworld but the number is not getting activated on the handset.I get the error message "Your phone cannot be activated,please contact Reliance".But the webworld had informed me that the Number has been activated from their end and I just need to dial *228 followed by the 9 digit pin number.So does anyone know the way,how I can find this out Please help ************************************ just type ODR and any lg rsn no. and get handset details for example ODR RLGHS(and rsn no.) and sms to 3738 and u will get 2 sms frm 3738 and 2811 ************************************** the no my dear is now 53733 so type odr<rsn> and send to 53733 u will get the first no that was activated on the rsn and moreover its activation date too No my dear. When you type odr rsn and send to 3738 or 3733 you will get the current MDN, ie number presently working on the handset, and also the activation date of the very first number that was activated on the handset when it was new and used for the first time. You will never get the first number that was activated, only the current number. And more, there are 3 codes which can be used by sms to either 3738 or 3733 If you do not know the RSN of the handset but only know the current MDN number active on the handset, you can type odm <mdn> to 3733 or 3738 You will get the date of first activation of the handset. Also, if you wish to only know whether a new GSK can be activated on the handset, then you should write getstat <rsn> where rsn is the RSN number of the handset, do not type the brackets <> Hope it helps now. Share this post Link to post Share on other sites
sanjeevlj 0 Report post Posted September 12, 2008 for example my cell got two number one on my cell and another on my uim i send both of them as ODR RLGHS(and rsn no.) and sms to 53733 but all time reply came as error- no record fetched for given rsn Share this post Link to post Share on other sites
drmadhu 87 Report post Posted September 12, 2008 Ruim based handsets no RSN Share this post Link to post Share on other sites
