Mahidhar
Songs Section
hey ppl,
does anyone know how to switch off the backlight when listening to songs in R world ? it seems to drain the battery real fast ... i've tried switching off the backlight under the display option, it still gets on when i'm listening to songs ... any idea how to get about it ?
bye
which hand set r u using?
in my handset i can change it from display/backlight and set it for a certain time or turn it off completly.. but if ur battery isnt lasting long then u better show it to the service.. i once saw a guy getting a replacement battery just because his bar was going down after making a few calls. they didnt even check the battery... but it was during a service camp. but it would be worth a visit. better get the battery replaced while its under gurantee...
thanx for the info sunil ... i'll get my battery checked asap. i'm using the LG RD 2030 set. i've switched off te backlight completely from the display options but the stupid thing still comes when i'm listening to songs on R world ... must be a glitch in software ... ok thanx anyways
bye
well it stays on for me too, but i dont usually listen to songs that much, but even then i dont lose power that much. so it has to be some prob with the battery
RWorld has her own lighting instructions you can never modify. My RD 2030 behaves like your s and Samsung SCH N-191 behaves in the reverse fashion!
Coders in reliance need some amount of standardization i guess!
cheers
Ashok
