charge 0 Report post Posted July 1, 2006 (edited) I got a free Reliance datacard (HUAWEI) with my Hp laptop a couple of days back and it worked fine for the first day or so... Now whenever I try to connect I get a dialog box saying "Authenticating username and password" as usual but it stays for quite a while and then I get an error saying "The remote computer did not respond". I tried reinstalling the software and tried connecting from a different location but I didn’t get any results. I can still make calls from the datacard without any trouble and my signal strength is quite high... Any suggestions? Is there any updated software I could download? Edited July 1, 2006 by charge Share this post Link to post Share on other sites
Arun 795 Report post Posted July 8, 2006 I would suggest cross checking the username/password and also the dial number which is #777 Share this post Link to post Share on other sites
Ashokjp 15 Report post Posted July 10, 2006 i have you have 2 pcmia slots remove card remove all softs uninstall all card stuffs put card on other slot and follow instructs and install it. it will work Share this post Link to post Share on other sites
imvikky 0 Report post Posted July 11, 2006 It happens with my 6130 all the time if I disconnect internet and I have to reconnect it I have to remove the phone from Usb and reconnect it to connect internet o/w I get the same msg.... Share this post Link to post Share on other sites
gvsraju2k6 0 Report post Posted July 17, 2006 Hi, I am also facing same probelm , after contacting Support they told me that my Card was used barred due to non-payment of the bills. Then i have contacted with the guy who given me the card, then they found that they have not entered my HP redemption code.thats why bill was generated wrong. They are in process of enabling my card now. Hope this will help you Raju Share this post Link to post Share on other sites
gvsraju2k6 0 Report post Posted July 20, 2006 Ashok, With My HP Pavillion I got Huawei EC321 Datacard free, i tried installing the Huawei software as mentioned in thier manual, But no use. Right now i am using the card as Normal dailup modem.Could you suggest any remedy for this probelm. Thanks Rajugvs Share this post Link to post Share on other sites
