Sukar 0 Report post Posted July 5, 2006 Hello, Iam using LSI 110. Battery life is poor in this model. I am not sure if everyone is facing this problem. But i have come across 3 of my friends who have the same problem. i can talk only for 5 or 10 mins even when have the phone charged for entire day. Once it beeps for low batt i have to hung up the call and immediately aftet i hung up the battery bars again will show full. Is this a known issue? Battery replacement is the only solution for this? Any other experices please share.. Thanks Sukar Share this post Link to post Share on other sites
Dushie 30 Report post Posted July 5, 2006 Hello,Iam using LSI 110. Battery life is poor in this model. I am not sure if everyone is facing this problem. But i have come across 3 of my friends who have the same problem. i can talk only for 5 or 10 mins even when have the phone charged for entire day. Once it beeps for low batt i have to hung up the call and immediately aftet i hung up the battery bars again will show full. Is this a known issue? Battery replacement is the only solution for this? Any other experices please share.. Thanks Sukar Hi there, how old is ur handset, usually the LSI 110 battery dies out in 9 to 12 months time. Call customer care, request for replacement battery, they will come and fix it for u, Share this post Link to post Share on other sites
Mr_Flop 0 Report post Posted July 6, 2006 Hi Sukar, The performance of LSI-110 battery is indeed very poor. The guarantee on battery for a new handset is 9 months so check from service centre the activation date of ur handset and even if one day is remaining rush there and get it changed... insist that they change it for u as they try to console you with all possible diviations that ur handset is faulty or charger is faulty or they may say that u have used too much so battery is not giving performance YOU JUST INSIST ON CHANGING THE BATTERY AS IT IS UNDER GUARANTEE. Well and if 9 months are over then also there is a way out (free of cost) but that we'll not discuss right now. When u have the new battery with u then observe following things to get max performance out of it. Make sure no cable faults or loose connection in ur charger put a small paper folded twice along the side of handset while putting it for charging so that there is no chance of hanset moving loose from its place. Let the battery get fully discharged and then only charge it again... Don't just keep on charging all the time. Don't overcharge charging time is approx 2Hrs. Before removing from charging make sure its not giving false indication of fully charging. Just to make sure its fully charged switch off charger and switch on again. If fully charged it hardly takes a second almost immediately turns Green when u put on the charger again within short time. AND MOST IMPORTANT DON'T MAKE OR RECEIVE CALLS WHILE CHARGING. Share this post Link to post Share on other sites
malayonline 0 Report post Posted December 23, 2006 What is that other way out ? And, if not, how much does it costs ?? Thanks. Share this post Link to post Share on other sites
izzner 1 Report post Posted December 23, 2006 whats the other way out Share this post Link to post Share on other sites
petar 15 Report post Posted January 11, 2007 My personal finding is that - MOst people dont follow the basic instruction PLEASE CHARGE YOUR BATTERY FOR ATLEAST 12 hrs before the FIRST USE. (even if light turns green) When the first charge is not done for 12 hrs... no matter what u do later on.. u wont enjoy the battery life. other measures are already mentioned in some post above. Share this post Link to post Share on other sites
Kunal Hemrajani 1 Report post Posted January 11, 2007 All the LG phones r suffering frm that problemz.. Share this post Link to post Share on other sites
hritik123 4 Report post Posted January 11, 2007 My personal finding is that - MOst people dont follow the basic instructionPLEASE CHARGE YOUR BATTERY FOR ATLEAST 12 hrs before the FIRST USE. (even if light turns green) When the first charge is not done for 12 hrs... no matter what u do later on.. u wont enjoy the battery life. other measures are already mentioned in some post above. Lg 110 has ****ty battery no matter what the explaination, lg 220 , color handset of walky is far better , it easily lasts for 2 days without charging Share this post Link to post Share on other sites
