kshys
Hardware Failure
I have been using my Laptop and the LG LSP 350R Rconnect all this while but suddenly there seems to be a problem.
I am getting the hardware failure error. Can anybody help? Is it the laptop problem? the USB Cable or the LG Instrument or the connection problem.
Thanks & Regards,
kshys
Definately with d cable,Install all drivers for d interface.If, already installed u can pull off & reinsert d cable to USB port.Definatly Ur problem will be solved.Or might be cable is internally damaged or Pins.Also u can try setting d baud rate in ur phone under data rate settings.
