rajvir_s
Pc Hangs With Nokia 3125
I am having trouble getting my Nokia 3125 to connect to internet from my PC. Cable is CA-42.
It installed OK. When I use the R Connect dialler to dial it starts dialing, the R connect dialler window gives the message "connecting to the device", there is activity on the phone display, with the data transfer images "Receiving" and "sending" coming on, but then the PC goes into a total hang and freezes up. I eventually have to power off and on manually to get it to restart.
The same set and CA-42 cable have installed on another PC and laptop, on Win XP without problem.
However, on my PC I was using a Samsung N191 earlier, and had no problems connecting to the net. This problem has occurred after I changed my set to a Nokia 3125.
PC configuration: CPU - Intel Pentium D 920 2.8 GHz 2 x 2MB L2 cache
MB - Original Intel 945 GNT, 800 Mhz FSB
BIOS - NT94510J.86A.3869.2006.0519.1533
RAM - 512 MB DDR2 at 667 MHz
HDD - Seagate 160 GB SATA OS - Win XP SP2
PC is other wise working fine. I have even reformatted the C drive of HDD and reinstalled Win XP, but problem persists.
Can anyone help?
