prasad123
Pcmcia:could Not Open Com Port
The R Connect datacard ZTE MC 315 was working fine until I deleted a LAN configuration to reconfigure it, as i changed my ISP. I am now unable to run the card. A message reads PCMCIA Application: Could not open COM port. I uninstalled and then reinstalled the software many times but the problem persists.
I am a novice in this field & would appreciate any help in solving this problem.
Thankyou.
i think the com port used by the ZTE card is now being used by your new ISP connection, delete the device on that port and problem would get solved.
I had the same problm while testing ZTE card in Desktop (using PCI to PCMICA adapter). Tested in Win 2K and Win 98, it didn't work. Then I tried in Win XP and it worked. Did you try XP ?
hi brother
it is actually problem of data card pls do not do any thing just visit to service center & say to replaced the data card.oter wise ask for DOA if (RELIANCE WEB WORD PROVIDE A NEW ONE).
thanks
