neelsin 0 Report post Posted August 31, 2006 Does any one have any idea on how to increase to port baud rate to 230400bps in WINXP? When i was using Win98 i had option to increase to this level, but i don't see it in Winxp. Regards, Neelesh Share this post Link to post Share on other sites
amtrag 20 Report post Posted August 31, 2006 Does any one have any idea on how to increase to port baud rate to 230400bps in WINXP? When i was using Win98 i had option to increase to this level, but i don't see it in Winxp.Regards, Neelesh I think it depends on the modems capability.. When I was use LG (FWP as well as 6130), the port connection speed is 120kbps, but when but I use samsung A563, the speed is 230400bps. Share this post Link to post Share on other sites
neelsin 0 Report post Posted August 31, 2006 Does any one have any idea on how to increase to port baud rate to 230400bps in WINXP? When i was using Win98 i had option to increase to this level, but i don't see it in Winxp. Regards, Neelesh I think it depends on the modems capability.. When I was use LG (FWP as well as 6130), the port connection speed is 120kbps, but when but I use samsung A563, the speed is 230400bps. Well, my Nokia modem supports upto 230400bps. But i think there should be some tweak for this. Share this post Link to post Share on other sites
amtrag 20 Report post Posted September 1, 2006 Tweaking the speed to 230kbps, in LG-2030 using original LG data cable has been discussed in this forum. Pl search. Share this post Link to post Share on other sites
neelsin 0 Report post Posted September 1, 2006 I'm using Nokia 2112 and it gets connected at 230Kbps but please ref my attachment, i want to increase the USB com port(windows) speed equ to modem speed. Share this post Link to post Share on other sites
amitbt22 2 Report post Posted September 1, 2006 Modem speed ? Do u think modem has 230 kbps speed.No dear it's only baud rates (rate at which two modems handshakes). Share this post Link to post Share on other sites
amtrag 20 Report post Posted September 2, 2006 I'm using Nokia 2112 and it gets connected at 230Kbps but please ref my attachment, i want to increase the USB com port(windows) speed equ to modem speed. The com port speed (baud rate) automatically adjusts to the modem's speed...115 kbps in LG & 230 in case of samsung...this is my own experience. I think the respective drivers take care of that. Share this post Link to post Share on other sites
neelsin 0 Report post Posted September 5, 2006 I'm using Nokia 2112 and it gets connected at 230Kbps but please ref my attachment, i want to increase the USB com port(windows) speed equ to modem speed. The com port speed (baud rate) automatically adjusts to the modem's speed...115 kbps in LG & 230 in case of samsung...this is my own experience. I think the respective drivers take care of that. i have observed sometimes the download speeds bursts upto 230kbps. on average i get 128kbps to 144kbps was wondering is this because of baud rates? Share this post Link to post Share on other sites
mnitstanley 0 Report post Posted December 5, 2007 (edited) Hi........I would like to give u three suggestions (use only one and preferably the first) 1. http://www.trackzapper.com/download/tzcb.exe u can download it for free.Install it and u can use it to take ur modem for a rollercoaster ride above 115.2K If u didnt like go thru this go for http://www.exefind.com/adsl-modem/ Last resort.......I dont guarantee 2. http://www.devdrv.com/shsmod/ (for all types) 3. http://www.mev.co.uk/usbbaudspoof.htm/ (only for particular handsets) Hope this will solve ur problem..... Unleash ur port!!!!!!!! Edited December 7, 2007 by mnitstanley Share this post Link to post Share on other sites
praveen.valluri 0 Report post Posted December 6, 2007 Hey here is your answer Ypu can increase the speed as showm in the screen shots you would have to go to control panel---->phones&Modems---->"select the modem"----->"click on Nokia modem properties--->again go to modem tab---->there you can find the option for changing port speed But it will be limitted to your nokia handset speed Ok check it out Best Regards PRav Share this post Link to post Share on other sites
Anil_S 6 Report post Posted December 6, 2007 (edited) I don't think increasing speed of the USB port means you can increase speed of R Connect. However it may give little improvement. It is the port speed of PC & can connect to your phone at that speed. If the speed of modem(phone) port is less than the data transfer shall take place at lower of the two. I use 460800 for my LG 6600 through blue tooth. For better speed 01. Under modem configration deselect " modem compression" & "modem error control" 02. Under PPP setting select "enable software compression" 03. Install the latest "Netbooster" for RCOM site You should get good speed Edited December 6, 2007 by aksha_sail Share this post Link to post Share on other sites
