Tushar 0 Report post Posted May 5, 2004 Is it possible for our LG RD 2030 handsets to have animated wallpapers according to me it should be since even animated bitmaps are possible isnt it ??? Look at ur windows startup screen bitmap 256 colour with animation at bottom isnt it so cant our phones also have animated bmps maybe. The only problem now is that I dont have a program for making animated bmps maybe some of ull could try it out and pls try to post program name if possible. I know the name of a program but cant seem to find it here it is BMP Wizard if anyone gets hold of it pls post. Share this post Link to post Share on other sites
StaticElectricity 8 Report post Posted May 5, 2004 no it's absolutely not possibly.. (hope that i might be wrong) but if what u are talking about .. it not a function of the bitmap itslef but it is because of the way that windows renders that logo bitmap. a bitmap as such can not be animated.. and for animated wallpapers i dont think it is possible since the phone should have an animation rendering subroutine if it is to be able to display animated wallpapers but I dont think it has one.. Share this post Link to post Share on other sites
karpar 1 Report post Posted July 1, 2004 i agree with static on that count. bitmaps cannot be animated and the simplest animations are created as gifs. but nothing seems out of reach when u have an lg rd2030!!! Share this post Link to post Share on other sites
Code 0 Report post Posted July 2, 2004 The default animations (themes) in 7130 are rendered by displaying a series on bitmaps (I think) but no one knows what is the format in which these bitmaps are packed together into a file(if at all) and also we don't know if such a option is available for custom wallpapers. It might well be as if U open the header of the wallpaers U see 8@ means a 8 bit bitmap. So what are the other formats allowed?? Also the java applets of webworld display gifs (though not animated) Anyone more info on that? Share this post Link to post Share on other sites
StaticElectricity 8 Report post Posted July 2, 2004 Also the java applets of webworld display gifs (though not animated)Anyone more info on that? webworld?? i think u mean r-world but i KNOW that most of the pics in java applets are actually PNG, the phone's also capable of showing WBMP images. Share this post Link to post Share on other sites
MasterMind 0 Report post Posted July 3, 2004 WBMP..???? That reminds of good old days of WML... I had used softwares for creating WBMP 4-5 years ago.... when WAP and WML was just coming up.. too bad it didnt work out as much as it was anticipated... Share this post Link to post Share on other sites
Code 0 Report post Posted July 3, 2004 OOps static __ I meant R-world BTW it also display png and wbmp as U said (they are much more in number compared to gifs) Share this post Link to post Share on other sites
rakesh5295 0 Report post Posted July 11, 2004 how come it has analog clock which is animated wallpaper or say screen saver. can we add ours ir change it. Share this post Link to post Share on other sites
StaticElectricity 8 Report post Posted July 11, 2004 how come it has analog clock which is animated wallpaper or say screen saver. can we add ours ir change it. well, the Analog Clock you say, i dont think it's a wallpaper or a screensaver. it 's a programed component and moreover , the program is in the rom, so i dont think it's possiblt to change it. Share this post Link to post Share on other sites
