VinayakSharma
Nokia N93 With Rim
Have any one tried Nokia N93 with RIM.
It says its dual mode GSM & WCDMA. One of my friend is keen on buying N93 to use with his existing RIM connection.
Any comments?
WCDMA is not the same as CDMA2000. WCDMA is the next generation (3G) of GSM technology. You can read more on the topic on wikipedia.
N93 would not work on Reliance CDMA. This has been discussed plenty of times on the forums, and a little search would have told you too.
Closing Topic
Guest
