n.b 0 Report post Posted December 2, 2006 (edited) Hi everyone, I am a new member. I want to use R Connect Platinum 100 plan which comes with Sierra Card for a monthly rental of Rs.1500 and unlimited surfing. Please let me know if I can avail this plan on desktop computer. I have a desktop computer with Windows XP, 604mb RAM and Pentium 4 processor. Somebody said me that data cards are only available/works with laptop. Please let me know if data cards work with desktop. Thank you. Also let me know if it is not availble then how can I avail 24 hours unlimited internet with postpaid or prepaid connection for a particular fixed tariff rate. (Not 50p per minute). Thank you. n.b Edited December 2, 2006 by n.b Share this post Link to post Share on other sites
basant_jp 0 Report post Posted December 2, 2006 With a 'PCMCIA card adapter for desptop', you can get the sierra card (and most other PCMCI devices) work on your desktop. Share this post Link to post Share on other sites
n.b 0 Report post Posted December 2, 2006 Thank you. How much does this 'PCMCIA card adapter for desptop' cost? Can you explain me a bit about it please. Thanks. Share this post Link to post Share on other sites
Puneet 0 Report post Posted December 2, 2006 Or you can get the new EC625 USB card, which will work as well with desktop PCs. Though the card is in short supply and you might have to run around a few WWs to get it. Share this post Link to post Share on other sites
n.b 0 Report post Posted December 3, 2006 (edited) Thanks. Can I avail Platinum Plan 100 internet plan with EC625 USB card? Actually I do some online content writing job, and I need all day internet without continuous connection errors as I face now. So I am planning to opt for reliance Platinum 100 plan. Also can you guys please suggest me which brand of 'PCMCIA card adapter for desktop' will work best with sierra card? A hardware seller said me abt G520+ PCMCIA card. Is it any good? Thanks. Edited December 3, 2006 by n.b Share this post Link to post Share on other sites
Arun 795 Report post Posted December 4, 2006 You can opt for any of the Data based plans mentioned here (under: For Reliance Netconnect Card only). Platinum plan doesn't have any limit at all. If you opt for Freedom plans, make sure you have an eye on the data transfer per month. Share this post Link to post Share on other sites
supernova 47 Report post Posted December 10, 2006 new buyers of the usb card pl. check before buying card whether platinum plan is being offered with tis usb card . i gotta know that from now they have discontinued platinum plan on usb card but still giving pcmcia card . can anyone confirm the news ? Share this post Link to post Share on other sites
