tanveer
Browser Problems
My Problems and queries
1. I am not able to download anything from Rapidshare using FF (1.5 as well as 2.0)
2. How to enable autocomplete in Opera?
3. I can not access many sites properly on FF eg. ICICI, IRCTC etc.
4. What are the best widgets for opera?
5. How do i get a bookmarks toolbar in opera?
I mean something like this
Edited by tanveer
Dude.... I can try to answer some of your FF queries (1 & 3)
All the sites work fantastic with FF 1.5 & 2.0. I think you're facing some plugin and/or extension issues.
Try using the USER AGENT SWITCHER extension to "emulate" IE and login to those sites. If that fails... I think I've diagnosed it correctly. You'll probably need to reinstall the Flash & Java plugins for FF. Also see if the sites you visit ask for any other specific plugin.
